Guilt-toy Now Running On E85 !
fark.. you guys are still going with this :)
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
It's stickied mate, thread'll nevar die!!!
I never tried the united stuff so i can't really comment on it, appart from saying it's f**king awesome fuel :thumbsup:
This was the wideband im thinking about getting, what do you think for the price?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
I agree, does it have a programmable output for the ecu? I find logging with the EMU the best way to track afr's.
I have the LC-1 kit, its been in for nearly a year with no issue. I know a few guys have had problems with these in the past but for $200 it has been a good buy. Perhaps running E85 prolongs the sensor life?
http://www.innovatemotorsports.com/xcart/p...=262&page=1
fark.. you guys are still going with this :P
I have used all three ethanol brands available from the pump, There wasnt that much between them but the Caltex E70 definitely starts much better in my car and feels stronger.
Im wondering if there is a happy mixture, with enough petrol to help burn the mixture completely during the downward stroke, rather than pump it out the exhaust...
interesting write up. anyone else tested the ethanol content of united's stuff?
btw the reason for caltex's higher price is they're simply selling it at 20c/L less than ulp regardless of the mix. so it goes up and down with ulp by the same amount, even tho its only 15-30% ulp
Ive only ever used the United fuel. No complaints here.
As for cold start it would start every time on the 3rd crank.
Ive noticed mine starts MUCH faster in the warmer weather we have had lately.
Starts just as fast as my commodore (which is straight away)
I have more of an issue as the fly-by-wire throttle doesn't allow me to give it a squirt of pedal to start, coupled with the Emanage not being great with cranking enrichment... I really appreciate the e70 any morning its under 15 degrees.
Not real impressed with Caltex's reason to swing between E70 and E85. Might be OK for those commodores but not for us with a single tune for 85% Ethanol.!!!
They are just following the US lead they have been told to follow. Its a GM global push.
Nothing 5 litres of petrol wont fix, the main hassle is you wont know when they are changing the mix. Remember, none of us are supposed to be running Caltex bio Eflex.
How will 5 litre of petrol fix the issue when the ethanol content is already less then it should/needs to be?
What does it need to be? Do you have an e85 tune from one of the other suppliers?
If you are running Caltex you will have an e70 tune which will run fine when and if they switch over to e85 by just throwing a few litres of 98 in... Good idea to have a wideband if you are playing with the Caltex brew.
It will be tuned on the United E85 so I would assume that would be 85%. But I now see what your saying. If you tune it on the "E70" and you get "E85" a few litres of normal fuel would make it a bit more even. But are you going to bust out the lab in the fuel station to work out what it is everytime you need a tank of juice?
If you call a simple wideband sensor and gauge a "lab" lol, United e85 seems to be e90-95 from my experience, the Southland Manildra blend is closer to the mark. I would suggest tuning for the fuel you plan to use.
i have mine tuned on E85 from united. was already mega fat on the dyno due to a problem we had on the day, but around the 0.76 lambda mark.
today at winton, with the caltex E70 in it, used mix trim to take out 8% of fuel and it was still at 0.71 on the meter (microtech meter only reads as low as 0.71).
caltex mix is meant to be from march to mid november.
im going to give it a week, then get a litre from caltex and do another test to see if the tanks have been filled with E85 yet.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
