Guilt-toy Now Running On E85 !
it's weird, my united only ever really varied from 82-85 - haven't driven the car for like 3 months, so not sure what's happening at the moment...
and caltex when i was using it was always bang on 70
deffinatly looks like e85 will be in armadale shortly.
an email from united today:
Thank you for sending in your query. At this moment, we do not have an estimated time for the completion of E85 upgrades for Armadale as there are many factors changing the final date. We will announce on our website and Facebook pages when E85 does become available.
i had also asked if a few other stations would be getting e85 and there response was:
At this time, we do not have immediate plans for expanding in WA. As we have just introduced ethanol blended fuels in WA, we are expanding our E85 network nationally and have included WA in this. We will pass your request for E85 for Hamilton Hill and Melville to the appropriate department, however, for the near future; we do not have any other plans in WA.
im still uncertain if i just hold off a little bit as im in the final stages of finishing my r33 off which is running a 6 boost, gtx3076, 50mm external gate and plazmaman plenum. quite a few have advised already that the gtx3076 really does require e85 to make the most from it. eaither way if i go e85 i guess id1000's will be the go with a walbro intank e85 pump. is it true that all the rubber fuel lines will have to be replaced with teflon braided lines?
No, it's not true, the lines should last for years on ethanol.
The GTX is fine on petrol, they just like more boost than the gt's. when you go e85 you can just wind the boost up more. Still a good turbo for 2.5L, although I wouldn't want to go any bigger personally.
Finally in Armadale (First in WA) and for those not in WA, Armadale is a shit hole at the end of the earth haha
Anyway I got some, tested in test tube for about 88% ethanol, Dave tested with a Zeitronix and got E80. It's normal for the test tubes to read high yes?
Yep on the south western cnr of Brunker and Rookwood roads .
Funny you should mention concern at getting tuned for E85 or Eflex E70 . I was tuned on E70 and gave United E85 a go and yeah it felt a bit flat/lean which the Tech Edge shows . After about 50-60 km I added ~ 6L of Ultimate and after a short time my car drove almost as it had on E70 .
It's not a problem using the E85 if tuned for E70 because all you have to do is throw in a small amount of straight ULP or prefereably PULP .
If you assume Caltex is E70 and United E85 then the difference is 15% more Ethanol in E85 , to get back to "E70" you have to add the 15% ULP .
If we assume you have a 55L fuel tank then 15% is 8.25L so thats how much ULP/PULP you add to a basically empty tank before filling up with E85 to get E70 . 8 litres of petrol is close enough IMO and 4 or 2 works neatly with 1/2 or 1/4 of a tank .
Something else to think about is that adding 8 litres of straight 98ULP to 47 litres of E85 probably gives you a higher octane better quality fuel for half of the 30% petrol content than Caltex does . In a perfect world E70 would be 70% ethanol and 30% 98ULP and E85 same deal but I bet the oil Co's use whatever cheap garbage they can get away with for the "petrol" content .
I should have another look at Yagoona United because if they have 100E10 you could probably throw 10L of that in to make up the petrol content if it's cheaper than BP98 . I don't think 1 litre (1.8%) either way in a tankfull is a biggie with these high ethanol content fuels but 1 extra litre of petrol probably runs and starts a smidge better .
Cheers A .
A .
According to whitepapers I've read, the anti-knock benefits of ethanol level off above 40% ethanol content. As an experiment it would be interesting to see what a 40% ethanol / PULP remainder would give. By my calcs it's a fairly easy 30L of E85 (actual 85%) and 30L of PULP98. You then end up with 42% actual ethanol content, 8% shitty fuel and 50% PULP. As compared to a dyno run of straight E85.
More octane is not automatically better, the higher the octane the slower the fuel burns but I'm sure you can reach a point where this is detrimental. An efficient engine has the fuel burn as quickly as possible, at the right time, in a controlled fashion. So having "enough" octane is vital for the controlled fashion bit, but throwing more octane at the situation is not going to give you any benefit.
Downside being you end up looking like a chemistry student at the bowser trying to get 40% actual ethanol content when you fill up :P
Yes I note your points . Mine is thats it's not a biggie if your car was tuned on EFlex E70 and you wanted to or had to use United E85 for whatever reason .
The detonation resistance of E70 and E85 may not be so different but going from one to the other with no other change shows up as an air/fuel ratio difference . My Tech Edge display showed about 0.03-0.05 difference but I wasn't going anywhere flat out .
Now that it's available on my flightpath I am going to try United E85 with enough added PULP to make E70 just to see if anything changes drivability or consumption wise because as said I suspect the 30 or 15% "petrol" is some cheap mouthwash to bulk the volume out and make cold starting easier than with straight ethanol .
I think I remember reading on American boards that the blending petrol content was some inexpensive base stock and to be fair it may help out with tank pressurisation in warm weather . I think it's this issue that supposedly drives the change in ethanol content in some places summer to winter .
The burning question , sorry , is how well does the base rubbish burn and what does that do for fuel consumption ? Heat is where part throttle consumption is IMO and real petrol may give off more heat for the same volume of base stock rubbish so may be able to use less for the same heat .
With the right AFR E70 and E85 probably make similar power in a sane street tuned car so if you can have E70 with at least half the dino content REAL PULP can it make a difference ? I'd like to go further on a tank of fuel not just for cost reasons but range reasons .
Whats life without a challenge , cheers Adrian .
yes Adrian all pump E85 use regular 91 ULP in the petrol portion. Only Drum E85 uses 98 PULP as the 15% petrol portion
E85 now available for you Newcastle folk.
United 114 Chelmsford Drive, Metford 2323.
Also good ole NECKNOCK too man!
Will go check out this Metford one in the next few weeks, mine was tuned on Eflex E70 so chucking it on the Jezmans dyno to check all is good with the 85 in its guts!
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
