lutch will max out at 300 anyways.
So only wanted to get about 280-285
My gearbox has been out 3 times already so I'm not too keen to go down the slippery slope of upgrade after upgrade
You don't need to upgrade injectors for that power goal.
scotty seems to think everyone wants over 9000 killer wasps
  • 1 month later...
  • 2 months later...
Washable stainless filters are not fine enough, the dreaded black gunk seems fine enough to get through them and clog the injectors. I was recommended to install 10 micron paper elements to guarantee it would catch the black crap present in e85. (I assume from the manufacture of the fuel.) Moran refuse to warrant their injectors without a similar filter fitted in the fuel line...
E85 is a great cleaning solution and should flush any varnish buildup through, but this can block the filter internal to the injector, which in the EV14's is nearly impossible to clean.
wait, what? gunk in E85 from the manufacturer? (I thought it might happen if petrol stations filled ULP tanks with E85 without cleaning the tank first).
Is this a common problem or isolated?
Common, it builds up over time and circulates your fuel system, building up in the injector filter eventually. (Which is deep inside the injector on the ev14's.) For some reason my fuel system has been fine for years, but I have replaced 3 sets of ID's for customers due to this black crap recently.
I have a feeling it is from the carbon filtering of the ethanol during production. It does look a lot like carbon silt.
Currently running my rb20 on e85. Using a bosch 040 intank pump, all lines are speedflow series 200 hose (teflon), with tomei fuel reg, aeroflow inline fuel filter, standard fuel rail, and 565cc hks injectors. Making 266kw/357 hp, and mine doesn't chew through fuel like that at all.. Dyno graph in the rb20 dyno result thread
  • 3 weeks later...
Nah easy. I just carry a laptop with a 98 tune on it in case I have to stop for 98. It never fusses over a few litres of E85 left in the tank, and vice versa.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
