Make:vw
Model:passat
Milage:125,000kms
Transmission:5 speed auto
Colour:blue
Complied?yes
RWC supplied?yes
Currently registered?yes
Price:$11,000 or swap for perfromance car
Contact:0410727690
Comments / Modifications none
Images:yes
here is some info on it
blue in color
1.8 ltr turbo
abs
5 speed auto
rego till april 2009
cooler box in glovebox ,good for summer to to keep drinks cool
aircon
sunroof
full leather interior
four air bags
8 spearker sound system
just had full sirvice done last mouth ,oils and filters,all the pads changed ,spark plugs.
All round the car is in very good nic and i have never had a problem with it and is very good on fuel about 650kms to a tank ,its a real classy car but i want to get another perfromance car and if i had the money i would keep as its so nice to drive and a real good cruiser ,ill put some pics up to moz and if you have any
questions feel free to ask .
https://www.sau.com.au/forums/topic/239283-2000-passat-low-kms-11k-neg/
post-56368-1223515467_thumb.jpgpost-56368-1223515483_thumb.jpgpost-9125-1124500198.jpg
Hey mate
I'm selling my 96' skyline r33 4 door gts-t RB25, for the same price.
its run 82,xxx kms
auto
Straight-six turbo 2.5L
location syd.
imported in 2005
fully stock other than 17" rims
as much as i love driving it, i need to get rid of it for a more fuel efficient car, so i am very interested in taking your offer for a swap.
Please let me know if you are interested.
Contact - 9303 3373 or 0415 347 614 or [email protected]
Cheers
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
