Model:R 33 M SPEC
Milage:76000
Transmission:5 SPEED
Colour:SILVER
Currently registered?YES
Price:$21500
Contact:0419 704 265
Modifications:SOME
Images:YES
ENGINE COMPLETE REBUILD 2500 KMS AGO
ENGINE CURRENTLY MAKING 440 RWHP ON 16 PSI
MODS AS PER:
MICROTECH LT12S WITH HAND CONTROLLER
GARRETT GT 35/40R TURB ON TOP MOUNT MANIFOLD
50 MM EXT GATE WITH SCREAMER PIPE
FULL 3 INCH EXHUST WITH OPEN CAT
CP PISTONS {FORGED}
COMETIC HEAD GASGET
RACE BEARINGS
BILLET HI FLOW FUEL RAIL
DENSO 680 CC INJECTORS
SURGE TANK & BOSCH 044
TURBO SMART HI FLOW FUEL PRES REG WITH GAUGE
TURBO SMART MEGA SONIC BOV
NICKS CLUTHES HP BUTTON CLUTCH
3 INCH COOLER
FULL 3 INCH S/STEEL COOLER PIPES
APEXI BOOST GUAGE
GREDDY EGT GAUGE
SASS STEERING WHEEL
SUN ROOF
TINT
HICAS LOCK OUT BAR
NEW 18 INCHMAGS
NEW 225 FRT TYERS
NEW 265 REAR TYERS
NEW BATTERY
NEW RADIATOR
FULLY RESPRAYED IN 2PAC
R400 FRT BAR
R400 SIDES
GTR REAR PODS
ANY QUESTIONS PLS CALL
MOTOR AND ALL ACC HAVE 2500 KM ON THEM
https://www.sau.com.au/forums/topic/239290-hi-horse-power-r-33-m-spec/
  • 3 weeks later...
  • 3 weeks later...
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
