Make: Nissan Skyline r32
Model: r32
Milage:
Transmission: manual
Colour:
Complied?yes
RWC supplied? yes
Currently registered? yes
Price: upto 10k
Contact:pm me or post here
Comments / Modifications: Hi everyone im after a non turbi r32 skyline. so if you got one your looking to get rid of tell me about it. Im mainly looking in NSW specifically central coast and Sydney area. Thanks
Images:
https://www.sau.com.au/forums/topic/239299-wtb-non-turbo-r32/
