Yeh i went through Extensive Wheel service, its 307 South Road Mile end. PH: 83525777.
I went there about 12 months ago....due to a bit of immature driving, smacked up all 4 rims pretty badly. They do a pretty damn good job tho i must say but it didnt come cheap, it cost me $165 per rim so it was a fairly costly experince. It cost more because the way they were bent and the fact they had deep dish, so it does depend on what rims u have on as well. Hope this gives u a better idea.
cheers
Adelaide Wheel and Rim quoted me heaps to do a simple rim job for my race bike a year ago, then turned around a week later when I checked up on it and said it couldn't be repaired. So I walked across the road to Extensive Wheel Service who did the job cheaper than AWRs quote and got it straight :/
The guy who runs EWS use to work for AWR and left due to poor service. The guy at EWS is more than happy to beat AWRs quotes.
if ur out north try ringing comercial metal polishing they have a guy that used to work at one of the 2 joints mentioned above but left due to management and has just joined up with gino there best of both worlds
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
