Does anyone have a paypal account they can help with me transferring a payment for an ebay item.
I thought the seller had bank details, but he does not ... and he's in the US.
:P
you just moved from a stones throw one direction to ya new house a stone throw the other way,have you forgotton we are here,i use ebay all the time remember,cum see me if you cant sort out,then maybe we will get an invite to ur new house,better late than never i spose
Hey Damo, thanks man, we might drop by tonite ... if thats okay. Tracy and I have been to PI and we've both been knackered LOL
I just need to paypal $25 USD or so ... was meant to be done before I left for the MotoGP, but oh well. I'll have the cash with me tonite to reimburse you, if you're available.
:P
why dont you just set up your own paypal? takes 5 mins and its for free =]
I know how paypal works ... but its never accepted any of my ACCU cards.
I've since only dealt with cash or bank transfer transactions, but this was a paypal transaction I got into before I was aware of it.
:P
:P
got to go down sth tonight,leaving bout 5,mrs at home all day if tracy not busy and wants pop over to see her with details,i can sort out for you when get home if want,or pop past 2morrow be home for sure can help then if easier
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
