yep the new subbies are f*kd,looked at a new one earlier this yr. how dissapointing.
same as the new lancer evo and standard lancer who the f*k designs them!
before they were aggressive with nice straight lines flat pannels and lookd hot as hell!
now ther are all bubbly,too rounded off for me
i quite like the grid concept one above, i think its pretty mean looking actually, if they brought that out in aus i'd get one......
I like the new subies... Then again I liked the Mazda GTR, Escort, and other hatchback rally cars from yesteryear.
Thats 2 of us, though I will admit I didnt like them at first but now they've grown on me.
However performance wise, Top Gear has written them off to the evo
My mate has a Subaru Impreza MY05 and had to get it serviced. When we headed down to the Subaru Repair shop, he encountered a problem and had to leave his car there, since they had no spare rentals etc one of the ladies decided to give us boys a lift home in her new WRX STi Hatch.
While we were driving she mentioned the fact that the MY09 Subaru's will feature a Sedan model that will only come in WRX and Impreza models but the STi model will be retained by the likes of the MY08 Hatch as it currently is the case.
Personally after hearing this and getting excited for Subaru again, after seeing the pictures of it, those thoughts of relief for Subaru went down the toilet.
As for the new EVO X and upcomming XI and 2009 lancers they look great, they are heading in a decent direction, as designers, the flat panel style we are used to is definately dead, just take a look at the new VE's, the GTR, everything is getting rounder etc.
The new sedan WRX looks SHIT!!!!! It's so terrible i dont know anyone who will personally take a liking to it. As for the Impreza model MY09 sedans they don't look so bad...the scoop and front grille on the Rex sedans look awful (for MY09's). I think after seeing the sedans i have grown alot fonder of the Hatches lol. Heres a pic from the Subaru site itself:
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
