R33 s1 turbo's ball bearing??
Bo0sT_JuNkY
 Share
14psi ?? Interesting....
Using the stock turbo and stock ECU im currently at 272rwhp. I'm still quite confident I can get the stock turbo much higher than that (well 285+ rwhp) with probably another $2500-3000 of various minor mods.
Jet..
~200rwkw is pretty much spot on for a RB25DET with a standard turbo running 14psi, aftermarket ecu, fmic & exhaust.
Some RB25DET's are freaks and make ~200rwkw with the above except without the aftermarket ecu.
i.e Bugalugs that also ran a 13.4 1/4 recently.
If I had a RB25DET turbo i'd be running it at 17psi.
You can't really compare the 14psi limit of ceramic turbo's when using a larger turbo on a smaller motor as at 14psi on the smaller motor the shaft speed of the turbo isn't going to be anywhere near as fast as it is on the larger motor. So up the boost so it is :D
Heat also kills ceramic turbo's.
So if you hammer it on a track day be prepared to loose a turbo.
I have noticed a trend with turbo's that are factory fitted.
For example the RB20DET makes 160kw at the flywheel, when boosted to approx 1bar they make 160-170kw at the rear wheels.
Same with the RB25DET's, they make approx 190kw at the flywheel and when boosted they also make around 190-200kw at the rear wheels.
Joel, this discussion will probably lead to the accuracy of the dynos. some dyno show better result than others. my car have all the mods you'v mentioned and it made 165rwkw at 14psi on a particular dyno. 165rwkw and 200rwkw is a huge difference, but in fact they might be generating the same power. you get my point?
yer it seems that all the dyno's down here are very very similiar
i.e a genIII commodore makes 200rwkw with certian mods throw a modded skyline with stock turbo and it makes 200rwkw.. get what i am getting at.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
