Hi Guys,
Just wondering if you can help me. I had a blown right-hand side headlight globe on my 1993. Now I got a R33 with both headlights which don't work after attempting to change the globes. I changed both new globes and checked all fuses. No fuse seem to be blown and I checked both the inside fuse box and the fuse box on the engine bay.
By the way can any of you guys tell me which fuses are for the headlights both left and right. Everything is in Japanese on my R33. I saw a diagram of a R33 fuse box on this forum but is looks nothing like my one.
Appreciate your assistance.
https://www.sau.com.au/forums/topic/239391-headlights-dont-work-need-advice/
Try this [see attachment], print it, laminate it, and stick it on the interior fuse box lid, if you didn't get the right globes, or they are not earthed properly that will also do it.
R33_Fusebox_translation.doc
Thanks for your advice and the diagram fellas, much appreciated.
Boss-zilla if you knew how to read which I doubt, you would realise in my original thread that I clearly indicated that I encounted this problem when I changed my globes, WHICH OBVIOUSLY MEANS I PLUGGED IT IN!!.
Like i said i was not having a go at you as i have seen people do this. infact the r32's can have two plugs in series for the head light globs and while changing them people have left one unpluged. There is no need to go off like you have as sometimes it is that easy also that nice little PM you sent has been reported, next time dont join a forum then abuse people.
Also the first rule of thumb when fault finding is to look at anything you have done that may, stress may have contributed to the fault.
If anyone had asked me what to look at if they had this problem i would have said the same.
1.Check the connection (are they pluged in?)
2.Check the fuse's
3.Get a test light and check there is power to the connectors.
So as you can see i was not having a go at you and next time when asking for help IF YOU think that someone is having a go there is NO NEED to write an abusive PM to said person because in future they and others that hear about it may not help.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
