SKyline GTSX 87
Black
rb20det nics
dyno'd at tilbrooks on 10psi at 120rwkw's,
More potential with some more boost and ecu rewrite. Or silvertop rb20/25
GTR intercooler with mandrel bent piping
Modified front bar to suit cooler + custom plate
VG30 ball bearing turbo
3" exhaust off turbo to stainless cannon style muffler
nardi torino leather wheel off WRX in perfect condition
boost gauge
16" mags powdercoated white
aftermarket adjustable suspension (height and damper)
Sony cd player and mtx thunder splits
new alarm with all the good features
cold air intake + filter
R32 x over pipe with bov (plumback)
ABS (not to many 31's have this)
HICAS
power windows, mirrors etc....
near new radiator, battery.
Very reliable and excellent car to drive, blows no smoke and turns many heads.
$9600 ono
[email protected]
0401 293 557
https://www.sau.com.au/forums/topic/23940-gts-x-with-mods-adelaide/
got some pics at www.pbase.com/gtsx_87
i also have some more recent pics so leave ya email addy and i'll post some through to you..
thanks junior zilla!!
sorry timmayyy.... want something much cheaper to get me around...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
