New Brakes
Hey all..
Wandering if yo can help me out. Im looking at upgrading my brakes all together to something like brembos off a GT-R or something similar..
Just a few questions one being will the stock GTS-T rims clear GTR brakes?
How much are we looking at for these brakes (in great condition) on all 4 installed?
Please leave any imput you have, i have done a bit of research on brakes and brembo's off a GTR look to be the most conservative safest approach. So if there are brakes which are similar or better please let me know..
Thanks in advance guys!
Sorry if im a bit nooby
I have R33 GTR brakes front and rear on my R33 GTST and it works well, just remember to upgrade your master cyl to a 300ZX one or a R33 GTR one. Not sure about the std wheels clearing them? You will just have to up grade to GTR wheels. :)
Good luck
not sure how much this upgrade will cost you
but in the group buy section look into RDA slotted dimpled rotors and EBC pads. seem to have done many a GTS-T owner justice on the streets and for track work braid the lines for better feel.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
