I think I could be about to have issues with the different LH engine mounts in a GTR and GTS-t R33. I am putting a twin turbo (stock set up) R26 engine into an R33 GTS-t shell. It appears some of the front turbo oil or water feed piping could interfere with the different engine mount used in a GTS-t. Has anyone doe this swap and can tell me about the issues? i am still assembling all the pipes and unions for the turbo plumbing, but from what i can see so far this could be an issue, in particular the steel pipe with the cops tail curl in it to the front turbo?
Thanks.
  johnbarry88 said:
Nismoid is correct just use the rb26 engine brackets and you wont have any dramas..
So using RB26 engine / GTR bodyshell engine mounts into an R33 GTS-t subframe with an RB26 twin turbo engine line up OK? Thanks.
