I need some advice on this problem i have in my R34. Well for some reason when i drive on the freeway reaching 100Kms around my feet area it feels like a heater blowing and it gets quite hot :happy: . Sometimes theres also a burning smell :banana: ?? Just wanted to know if this is a common thing or i should get it checked out?!??!!?
https://www.sau.com.au/forums/topic/239484-getting-hot-in-here/
Check that maybe you turned off the circulation for ur air-conditioning and left the vents open for the outside air to come in?
There's a white plastic pipe behind the car air conditioner which blows the heat into the car but sometimes it breaks (mine did and i felt like it was blowing hot air onto my feet) you need to take your deck and all that crap out and reattach the pipe as i'm assuming its popped out in the direction of your feet. Otherwise i'm not sure whether you know how to use your air con haha
turn your climate control down as low as it will go (18?).
If you have it set to say 24, the fan turned off and your window down, you would think your heater is off. In reality the heater is on (because its sensing it's colder than 24) but not blowing. If you have your vents set to "fresh" it will be collecting the heater hot air and spitting it out as it passes through the system.
Wow that sounds confusing.. Just turn your temp to 18 and see if it still happens :kiss:
Hope that helps
I noticed this also when i first got my skyline although i could be a few things first thing to do is check that its on 18 before turning it off, if it is still hot air coming through proceed to the next evaluation
Common problem with 33's and 34's mate. I have checked this with Fabian from X-Speed/Autobahn Mandurah. I first noticed it after my 100,000km service from Autobahn driving home at like you said, around 100km/hr-ish really intense heat comin onto my feet. I pulled over straight away thinkin they farked somethin up in my service and called them back up.
If it gets too hot for you, while the aircon/fan is OFF, turn the knob all the way to the left and you will get cool air coming out, even though the fan/air con etc is OFF, it still effects the temperature coming out by your feet.
So Hope that helped. :kiss:
Edited by Magic
So Hope that helped. :(
Yes, exactly what he said... just turn the knob to cold, easy as! trust me i know...lol
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
