would be interesting to know how much thrust it really puts out. my mates brother in law has got a propper model aircraft jet engine, and he had it bolted to a big heavy wooden table (the kind that takes a few people to move), and he started to spool it up one day, got to about 15% throttle i think it was and it started moving the table.... with two big blokes at the front of it trying to stop it moving. theres some pretty serious shit out there in relatively small packages.... only question is how to mount a gearbox to the back of one lol
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4187103
You can find instructions on the net. The outlet of the compressor is fed to the exhaust inlet, mixed with fuel and ignited.
yeah have seen some instructions on the net seems easy to do....
outlet of compressor goes to a combustion chamber then to exhaust inlet. need to have a sprk plug in the combustion chamber
to ignite the LPG.
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart :(
and also what sort of oil pressure i would need to run for the turbo.. im thinking it would need a good oil cooler too.
i have read that you can get these things revving to about 130,000 prm :ermm:
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190339
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart ;)
i have read that you can get these things revving to about 130,000 prm :)
pretty thick cast iron with a gaping hold in the back of it (where dump pipe normally goes/where thrust is generated) i rkn you could get heaps of pressure in there no worries.
and turbos spin well past 100,000rpm on your car anyway, what you've mentioned isnt anything crazy
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190393
Well there are two main ways of doing it. You can connect a shaft directly to the rotating center of the jet turbine and feed it through a huge reduction gear or you can use the outbound trust to turn a "windmill" feeding a smaller reduction gear. The yachts I work on, some have jet turbines, they're great! little maintainance, produce masive amounts of HP in a very small package.... great for getting your 600gt 200+ft yacht to do 40+knots (and engine room fires!) and they run on straight diesel!
As for an automotive application, I would use it in conjunction with your piston engine. Use a "windmill" connected to a reduction grear, to an electromagnetic cluch arrangment, drive shaft, feeding a modified gearbox... hmm
Hell you could probably have a go at feeding the power to the front drive transfer case on a GTR gearbox... for a laugh!
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4192370
im not familiar with jet engines and jet turbines, i know they use one in the y2k jetbike, and they use em in helicopters and tanks n shit, just didnt know they were the same sorta thing, how do they do it in choppers and tanks and stuff?
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4199856
I'm fairly shure the y2k was a direct shaft drive through a reduction gear (2 speeds- faster and stoopid fast) with some style of "buffer" or "slipper" clutch... Tanks are either multi geared (auto trans) direct drive, or hydraulic pumps and motors driven from the turbine and choppers are either direct drive or the turbine drives a generator that creates DC power to drive an electric motor coupled to the blades.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4200992
so how fast do these bigger motors spin? like in the y2k or in choppers/tanks? what about the diesel ones in the yatchs?
18000-25000 rpm is the upper working range of the larger units I've worked with. Helicopters probably more... Y2K less.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4203280
The hard thing is getting the flame holder right, you want it to burn all the fuel before the turbo but not blow out the flame when giving it some throttle.
Here's a good link for a really basic one - http://www.junkyardjet.com/primitive.html
And finally, a good use for a spare set of N1's ;)
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4204884
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
