Item: ohlins shocks and eibach springs to suit 33 gtr
Age: unknown. have been on the shelf for 3 years
Condition: excellent. no leaks
Price: 900 firm, pickup in sydney
To Fit: (What car) 33 gtr. (34 as well?)
Comments:
valving and springs matched by the good people at Mines.
circlip adjustable ride height (and full adjustable spring seat conversion is possible if you need it using a threaded base like Sydneykid does on his bilsteins). plenty of ride height options on the fronts, only 3 on the rear but it is easy to add more.
adjustable damping
eibach springs
pillowball top mounts
these are excellent shocks, not a set of japanese monroes like a lot of the coilover kits going around.
https://www.sau.com.au/forums/topic/239544-ohlins-coilovers-to-suit-r33-gtr/
Judging buy the length and width of the spring as well as distance from each coil I would say it would be street.
My Ohlin Springs make those springs look tiny.
yeah sorry I don't know the exact spring trates but they are definately road spec, not silly rattle your teeth out track spec (although they will still be fine for the occasional track day, especially if you do sway bars as well).
  • 2 months later...
  • 3 weeks later...
i run pretty much the same setup on my r33 gtst
great shock, pretty firm but not too crazy for the street.
shock reconditioners in browns plains are also able to rebuild and re-valve these
they have quoted me $220 a shock to do so.
Good luck with the sale Duncan :D
I have these for my R33 GTR. They are an exceptional item. I have used them on the track with no worries. Maybe slightly soft, but on a road/track car they are perfect. The adjustable damper goes so hard they almost feel like solid rods.
just in case anyone cares, Biketek in Leumeah (Frank) is the go-to guy for ohlins service and reconditioning.
His front desk has all these posters signed by superbike riders. "Thanks, Frank." type scribbles on them..
he charges less then $200 for full servicing per shock, and that is worst case ..
He is doing my ohlins flag-r right now.
Edited by moneypit
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
