Advice Needed With Chipped Ecu.
Daboss
 Share
Hey forum just wanted some expert opnions on this problem I am having. Have a skyline r33 gts-t mods are in sig. I recently upgraded my ecu to a 300zx ecu chipped and rewired to suit the rb25, now the problem is the car starts but idle it sounds sick its coughing and sputtering and barley kicks over and it can't rev cause when I rev it it doesn't really want to and feels like its bout to cut out. I also noticed the fuel pump doesn't prime as long with the chipped 300zx ecu installed. I just want to kno if it is safe to say the tune on the chip is crap?
first off if you have put a new ECU in you should let it idle for about 15mins i think, correct me if im wrong?
but i rekon its going to be related to the tune that the ECU has already. When they chip ECU the remap the the fuel and air maps to suit the car that it is fitted to.
the car it came off what mods did it have?
Was it chipped for use on rb25 or vg30. As nismoid said sounds like afm to me.
Although if you made the wiring changes then you're probably switched on enough and aware of the need to run a z32 afm with a z32 ecu.
Well as far as I know it was supposed to be chipped for an rb25 and as I stated my mods are in my signature, so you guys should have seen I have a z32 afm already. I didnt get a proper ecu cause the only ecu I want would be a pfc and they are very hard to find and expensive so this was a quick fix until I could get one and I wanted to keep the knock retarding feature of the stock ecu. The car the ecu came off was a stock z32.
I have posted up the wiring changes to use a z32 ecu somewhere here.
Nismoid is still on track I believe and I'd try a std z32 ecu.
Can you get the rom image off the chip and post it up, then we'd really get to the bottom of this.
I believe that this is a viable solution for r33 ecu woes esp.
So don't look at this as a quick fix as I fail to see the benefits of using a PFC now that you have made the wiring changes.
Use Nistune with wideband and I feel that you would have a superior setup anyway.
Let the flaming begin!!!!!!!!
Edit found wiring changes doc.
http://www.skylinesaustralia.com/forums/in...t&id=156978
Edited by Mr Jollwah
With standard z32 ecu car cranks but does not turn over. Nismoid said that they could have thought rb25 afm right? But, seeing as I have an afc neo attached to the ecu with the settings to run a z32 afm wouldn't that overide the rb25 afm signal and send the z32 afm signal to the ecu? When Nismoid said to use a stock ecu he did mean a z32 one right or did he mean a rb25 one?
rb25 one, the one thats made for the car, not some abortion
LOL abortion I like that. But i rewired and put the standard rb25 ecu in an the car started an ran fine. Swhat would your expert analysis be, that the tune on the chipped ecu is bad?
Yea I was using the neo with the z32, but the neo is untuned only change on it was to allow me to run a z32 afm with the the stock rb25 ecu. I got the ecu for about 80 dollars. Hmm do you think that could be the prob that I forgot to change the output of the signal back to a z32?
Its a possibilty, I mean if the ecu was supposed to use a z32 meter and you have a afc altering the signal then I guess that would cause some grief.
PM if you want sell this ecu later on...
would l be correct in thinking this is one of those 'universal' type mod chips? The ones which are designed just for the sake of it rather than tuned for your vehicle?
Ive heard these things cause more damage than good but correct me if im wrong.
Cheers
Hang on... your running a chipped/modded ECU... AND a AFC???
What on earth for?
Cause I did not disconnect the afc when rewiring and I was thinking I could use it to fine tune the ecu a bit after the install. Yea I guess you can call it a universal chip, but it only works with the rb25, as they didnt put my car on the dyno just used base rb25 maps, advanced ignition, remove speed cut and designed to use z32 afm. Hence why I figured i could use an afc neo to fine tune it.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
