I just bought the bosch 910 fuel pump to go onto my R32gtst, Man its alot bigger than the stock one. How did you guys attach the strainer on the bottom to the new bosch fuel pump and how do you connect the top hose from the fuel pump to the existing pipe.
anyone got any pics of their install? someone told me i have to buy some earls fittings. True?
Has anyone done this before coz i need a hand hehe..
Thanks guys!
https://www.sau.com.au/forums/topic/23957-910-bosch-fuel-pump/
  • 5 months later...
i gotta put mine in soon, to make it fit, i was told u have to cut the pipe going down to the pump, so its shorter and join it to the top of the pump with rubber hose and clamps. there shud be lots of info in the search section
the height of the sock when fitted to the new pump shud be same height as standard so the pik up point is the same.
yes: jvs007 speaks the truth :)
sky32t: if you read the posts a little more closely, it should be covered in there.. basically some thick hose can be used to extend the filter to the bottom of the tank where the original one did sit .. hose clamps can be used to attach the pump and to sit it correctly on the bracket.
You will probably need banjo connectors depend on how your pump comes, which may require a visit to Earls, Enzed, or another hose specialist.
Those threads should be in the FAQ section, in much a lot of stuff should thats trailing down and you have to search for pages and pages to find what you're looking for :) .. mods!!
There was kind of one, but buggered if i can find it :) .. Me, JimX and Steve were doing roughtly the same procedure at the same time on each of our cars.
It appears we lost most of the user uploaded pics in November or so when there were a few probs :)
You're moving down to Brissie sometime soon aren't you? If so I'll be happy to help out if you can wait that long.
/me starts ferrets away on hard drive.. digging up old pix..
okz... digging successful here we go.. These were with my old camera so you'll have to excuse the quality. The 3rd photo shows the tank cover with the lid removed.. the 2nd shows the stock pump assembly removed and what it looks like
The 1st pic is how I rigged up the new 910 before putting it back in the tank and putting everything back together again.
Here is the exact thread i was talking about, unfortunately with no photos anymore: http://www.skylinesaustralia.com/forums/sh...00&page=1&pp=25
Basically the procedure is this:
1. Get into boot near battery.
2. Use socket extender with a hammer (tapping) or some ghetto method to unscrew the jaw leading to the tank. This has to twist off (just like a jar top), and is fiddly. Proper way is via a custom tool, however a gear puller may work if you have one.
3. Remove rubber inlet and outlet fuel hoses going into tank. Unclip electrical plug
4. Remove lid, whole pump slots into a bracket inside. Should all come out as one piece, bracket and pump if you pull gently. Can now take it away and work with it somewhere suitable.
5. Remove old pump from bracket.
6. Remove fuel hose from metal feeder hose going to bump.
7. Gently pull off the plastic connector, and sock filter from bottom of old pump.
8. Use sufficient hose to go from bottom of new pump to fit over plastic bit of the filter. May need to shave the old tabs of the filter off. Use small hose clamps to secure top and bottom (shown). You want the distance of the reach/angle of the filter to be able the same distance as the old pump.
9. Connect banjo connector to top of pump. Connect the rubber feed hose to this connector.
10. Secure new pump to bracket. I found that one thick hose clamp did the trick.
11. Slot new pump+bracket assembly into position in tank. Be sure to align filter/draw point to angled left side of the tank (same position as old pump).
12. Reconnect all hoses, plugs, etc. Give it a run with the jar off, then do up tightly.
All of this will make more sense when you actually start pulling it apart.
Warning: Note that I can't guarantee the method I used is a very professional or the "best" way to do it, but after months mine is still working perfectly. I must have got the draw angle correct too as it will go right to yellow fuel light without falling over.
Will not be responsible for your self immolation!! Petrol is dangerous!
Guest darrinspencer
It is a good idea to do this when there is not much fuel in the tank
Otherwise you can not see what your doing in the tank if it is full
Predator-
Your first photo shows the stock pump and fuel filter pickup
The position of the filter pickup is in a different location to the new location with the bosch pump.
I installed mine in the same position as the factory height on the bracket, but I have surging problems around left hand corners when the tank is about 1/4 full or less
I am going to remove the pump and try lowering the pickup as per your third photo.
I also had a problem re fitting the new 910 pump back into the tank
I had to mount the pump as high as possible on the bracket so the pump did not hit the side of the tank
This meant I had to cut the factory metal pipe on the bracket out of the way.
Did you have to do this?
Hey Pred! I might take you up on that offer, I'm not to confident when it comes to fiddling with the fuel system and petrol at the same time :flamed:
Moving back at the end of March, will let you know...
cheers guys
hey suppose I wanted to mount the pump outside without a surge tank
would it be ok to just run it inline with the standard pump
and draw the current by splicing the power wires and running the 910 in parallel with the standard pump?
darrinspenser: yup, this is true :D I did this I think at the time so that I could position it right down in the tank a bit further than stock as I didn't think it would hurt. The only time I do have any form of surging problem I think the only time this has ever happened when the tank has been nigh on empty, going around a corner hard, etc. You'd probably get that with the stock pump anyhow.
with my 910, I left the metal tube in place (as you can see its almost a bit of a brace up the top there), but its not needed. You'd probably definitely have to remove it for a large pump, 044 or similar.
When I think about, with it fitting back in, I think I recall bending the bracket out slightly a few degrees from where it slots in, and that is probably the real reason for the extra hose length ... to get the draw point in the right position again. I've made a quick diagram of it - so people can visualise what I mean..
lukits01: yup, I believe that is how its done, one pump lower in the tank feeds the other higher up in the tank. The greatest work the pump does in drawing it up out of the tank, so a secondary pump works outside onwards, working to pump it to your engine. I think that is the theory anyhow. You can also do parallel pump arrangements for different reasons. I'm not really an expert on that, so maybe somebody else can help there.
Me either really, and I was really cautious the whole way through but i think in the end it is a relatively safe operation (fuel vapours need a good supply oxygen to ignite, and there is not much in the tank)
  • 4 weeks later...
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
