Hi all, I was wondering if anyone can help me.
I have an r33 GTS-T. Mods are FMIC, Pod, 3" Cat Back, 11.5lb boost, fuel pump, HKS BOV.
It started to have the slightest miss occasionally on idle and if you just feathered the accelerator it missed slightly for just a second as the revs built.
I then swapped my iridiums for copper heat range 6 gap set to .7. (to get over my "blowing out the spark" problem)
Now the idle miss is much worse than before especially when cold.
It also extends much further into the rev range.
At high revs or high load it is fine. It screams to redline smooth as.
I have tried everything other than changing plugs.
I was thinking to change gap to .8, next to change heat range to 5.
Any ideas would be greatly appreciated as it is very annoying.
Cheers.
Edited by fletch63
https://www.sau.com.au/forums/topic/239572-misfiring-r33help/
get yourself some splitfire coilpacks for starters.
and get yourself some heat range 7 gapped to .8
think there BK7RE? there the best plugs 2 use...
my 2 cents... lower ya gap ya plugs the worse your miss fire is gonna be on idle, mine use to do the same wen i used band aid fixes.
Try having your injectors cleaned. THIS IS NOT A COILPACK OR SPARK PLUG FAULT
Your coilpack would have to be pretty fubar to miss at idle.
I agree. I changed gap on my coppers from 0.7 to 0.8 and it is ten times better. Just a little bad on cold start. I am now lookn at IAC or AAC valves. What do you think.
I have previously tried 2 diff types of injector cleaner Wynns etc..............?????????????
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
