Hi all, I was wondering if anyone can help me.
I have an r33 GTS-T. Mods are FMIC, Pod, 3" Cat Back, 11.5lb boost, fuel pump, HKS BOV.
It started to have the slightest miss occasionally on idle and if you just feathered the accelerator it missed slightly for just a second as the revs built.
I then swapped my iridiums for copper heat range 6 gap set to .7. (to get over my "blowing out the spark" problem)
Now the idle miss is much worse than before especially when cold.
It also extends much further into the rev range.
At high revs or high load it is fine. It screams to redline smooth as.
I have tried everything other than changing plugs.
I was thinking to change gap to .8, next to change heat range to 5.
Any ideas would be greatly appreciated as it is very annoying.
Cheers.
Edited by fletch63
https://www.sau.com.au/forums/topic/239572-misfiring-r33help/
get yourself some splitfire coilpacks for starters.
and get yourself some heat range 7 gapped to .8
think there BK7RE? there the best plugs 2 use...
my 2 cents... lower ya gap ya plugs the worse your miss fire is gonna be on idle, mine use to do the same wen i used band aid fixes.
Try having your injectors cleaned. THIS IS NOT A COILPACK OR SPARK PLUG FAULT
Your coilpack would have to be pretty fubar to miss at idle.
I agree. I changed gap on my coppers from 0.7 to 0.8 and it is ten times better. Just a little bad on cold start. I am now lookn at IAC or AAC valves. What do you think.
I have previously tried 2 diff types of injector cleaner Wynns etc..............?????????????
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
