hey all
after the worst day ever yesterday... well not really the worst, but it was pretty shit... i need a new water pump asap!!
ive searched through the forums only to find a "this person said this will fit" or "this will fit but this is different" etc.
im running low on cash, so i dont want to find out tomorrow that the one i got doesnt fit and have to get another one.. i also need the car asap.
i want to know, from someone who has done it.. what water pump you used... where you got it from.. what the part number is.. and maybe how much.
noone has a listing for an rb20..
PLEASE HELP!!!!!
ive had the car, not even a week, and i spent all yesterday finding another radiator after mine cracked, put it in, and then the water pump shaft decided to shit itself and sling the fan into my nice new 2nd hand radiator.. and my bike is on the fritz... im at my wits end!!
cheers
Linton
https://www.sau.com.au/forums/topic/239592-rb20-water-pump-what-will-fit/
dude go into like sprints or an auto shop (sprints is in SA, not sure about NSW) and ask for a VL water pump. RB20s bottom end is the same as a VL
shouldnt cost too much, will be shit load cheaper then genuine :spank:
yeh i got an RB30 one and it fit straight up... absolutley no dramas. cost me $80 for an aftermarket one.. wanted to go genuine but nissan didnt even have one. will be getting a better pump when i have some more cash and more time.
NOTE: ALWAYS REPLACE YOUR WATER PUMP WHEN YOU DO YOUR TIMING BELT!! I BOUGHT MY CAR WITH THE BELT DONE, BUT THE WATER PUMP NOT TOUCHED, AFTER 4000KMS THE WATER PUMP SHAFT SHAT ITSELF AND SNAPPED AND THREW THE FAN INTO THE RADIATOR, COSTING 2 DAYS WITHOUT A CAR, A SATURDAY PULLING IT ALL DOWN AND $300 THAT COULD HAVE BEEN BETTER SPENT. THIS WILL STOP YOUR CAR WHERE EVER YOU ARE... PUTTY ROAD... M7... F3... COULD BE JUST IN THAT SPOT WHERE YOU GET NO MOBILE RECEPTION..
cheers
Linton
It could be even worse, have a look at your old pump if you still have it, normaly the first thing to go is the seal and it leaks water from a little hole in the bottom of the pump, check to see if there is sillicon in that hole.
I just recently had to do my water pump so i did the belt as well, only problem is that one of the bolt holes you use to get the balancer off was stripped so it tokk us 4-5 hours just to get that off.
Another tip, NEVER buy a second hand pump, for all the work you have to go through to change it there is no reason to risk using s second hand unit.
    • Yep that makes sense, thanks! I guess flogging these turbos in winter is more preferrable lol.
    • Bahahaha, bloody hell Greg. You've got bent and broken things, but instead, you're replacing perfectly good items. This story keeps getting more gregged!   Also, I'd 100% replace that reo if I were in your shoes, unless you panel beater is REALLY good. Even if you put another GTT one on there. Just because you've done so much nice body work lately, I'd say repair the body work fully  If it were more drift car spec, I'd be all "Hit it with a hammer and send it!"
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
