Item: Series 2 front and rear seats
Age: 12yrs
Condition: consistant with age, pretty good
Price: Make an offer
To Fit: (What car) and 32 or 33 coupe
Contact: post or pm
Item: stock clutch
Age: Unknown
Condition: working fine when removed
Price: $50
To Fit: Any
Contact:post or pm
Item: stock side mount intercooler
Age: 12yrs
Price: $50
To Fit: rb25det
Contact:post or pm
Item: Turbo smart bleed valve
Age: 2 months
Price: $50
To Fit: any turbo car
Contact:post or pm
Item: Bucket/race seats with rails - black
Age: Unknown
Condition: no rips or burns
Price: $400 for the pair
To Fit: any 32, 33, 34 coupe
Contact:post or pm
http://justjap.com/store/product.php?produ...=268&page=2
https://www.sau.com.au/forums/topic/239599-fs-r33-gtst-bits-and-pieces/
  • 3 weeks later...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
