Car:
89 R32 GTR
Problem:
Misfire at idle and when i try to hold it at a certain amount of revs (e.g) 1500, 2000, 2700, etc etc., it idles at 1100-1200 rpm, and if i rev it to about 3000rpm and let my foot of it tries to stall on me. (1 out of every 3 times)
it revs up fine and boosts ok. but wont sit at any certain amount of revs.
tried:
coilpacks
plugs
cleaned/checked AFM
Replace coilpack wiring harness.
replaced all intercooler clamps etc.
any help would be great.
https://www.sau.com.au/forums/topic/239605-urgent-help-needed/
  • Replies 42
where are the AFM's... likely too close to the comp housing.
Why you running all that stock gear with a T04Z anyhow? (and dont say 'running in' the motor)
i have 700cc injectors to go in, and plan to get a power fc, but i wont spend the coin on a power fc incase i need the cash to fix whats casuing the misfire.
so just want to get that sorted first.
don't think the afm's are too close if they were any further from the turbo they would be outside of the car. i can barely fit a thin hks filter between the afm's and the washer bottle and passenger headlight.
i just went and checked for error codes again and got: #21 (ignition signal system) my manual says: ignition signal is not generated continuously even though crank angle sensor is entered (dissconection between power transistor and control unit).
i check voltages to the coil packs and igniter but how do i check the sginal wire?
Check that the part where the CAS goes into isn't chewed out. It allows the CAS to flop around, and jumps timing up and down and causes mis fires mainly when attempting to hold revs constant.
fits snug in there..plus its held in by the 3 bolts
no error codes anymore... #55 (all good).
the misfire became less when i fixed an injector plug up (was still missing). after driving it a bit the miss gets worse and it starts to idle at 1500 rpm again. and goes up and down from 1400-1500.
given up.
given up.
when cold it idles at 1100rpm and doesn't miss... then about 30-40 seconds later it starts...the hotter it gets th worse it gets..
(sounds like dodgey coil-packs but i've changed them and they wouldn't make the revs rise to 1500rpm at idle)
anymore ideas?
STILL HAVE A MISSFIRE!!!
I have now done:
new plugs (3 sets)
coilpacks (3 sets)
new coilpack wiring harness
New injectors
New Power FC
New Z32 AFM's
Crank angle sensor
just check to make sure you have no vacum leaks. its along shot but start from there. correct me if i'm wrong but didn't you have a problem a couple of weeks ago with it not starting?
i have checked for vaccume leaks and also replaced all hose clamps... i wouldn't have thought that would cause it to missfire...
yeah i had trouble with it starting... had no power to coilpacks..(all sorted)
To save reading previous posts... this is where i'm at.
I need some more ideas please...
Problem: Missfire
What happends: runs fine for about 5-6minutes (only when started from dead cold, once its a little warm it missfires every start), then starts to missfire, if you give it a few revs and let the throttle off it dies for a split second and then the revs go up to 2000rpm (at idle) then slowly come back down to 1200rpm. (missfire the whole time)
replaced:
Igniter pack
Coilpacks
Plugs
Fuel regulator
Injectors
AFM
Replaced all hose clamps
checked all possible air leaks.
new power fc
new o2 sensors
New temp sensors
New ignition wiring harness.
the engine is fresh and has had all new gaskets fitted etc.
Any more help with this would be great. I'n my head i feel its a vaccume leak issue still... what else would cause the problems mentioned?
Edited by BNR 032
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
