Hi guys
Well, went through regency the first time and I got 2 bloody pages worth of things to do to the car, to clear the defect. :banana:
If I had the time I would probably do everything myself, but I want the car on the road asap,
So, I was wondering if anyone know of a workshop that can do this type of work, maybe if you have had good experiences preparing a car for regency with them or something. Might need to borrow a few things off them as well, so hopefully someone that has all the stock gear for those situations.
Its nothing major, just lots of annoying little things here and there...
Cheers
https://www.sau.com.au/forums/topic/239607-workshops-for-regency-stuff/
SMOOTH GARAGE!!!! i couldnt recomend them enough and they will hook you up no prob. plus regency is just down the road from their place.
there is another place on main nrth rd, but they are WAY to over priced and everytime ive been there ive left with a bill of over a 1k :banana: so i wont even say their name haha
i wasnt going to say their name but owell.
its a shame that they are so overpriced because they do decent work and are a great bunch of people! i just cant afford to go their anymore and come out over a grand less everytime for such small things!
The infamous list:
- Horn to operate (need a steering wheel that works)
- Number plates lights (rear)
- All lights to operate
- Pedal covers to be rubber (not aftermarket.)
- Tighten front seat belt buckle
- Brake fluid level low
- Replace left indicator (broken)
- Repair rust through battery tray+skirt
- Brake hoses to be secure (need some hoses that come with the fittings that go on the clamps)
- Remove rose joints on all rear suspension + front torsion bars (fit stock gear)
- Replace LH engine mount
- Replace split rack boots
- New Gearbox rear mount to be fitted
- Rectify brake fluid leak LH front hose
- Fit split pin to LH rear lower joint control arm
- Replace worn lower shocker bushes on rear shocks
- Rectify free play LH rear wheel bearing
- Engineer Hicas lock bar as well as rear lower control arm mount (been welded back to crossmember)
I can do a few of these things, but the ones in blod I want done by the workshop.
I am waiting on a quote from smooth garage, boostworx....well I dont have 5 weeks to get in, I want to do it next week.
Any other ideas?
Cheers guys
The infamous list:
Any other ideas?
Cheers guys
Holly crap dude
the guys at regency really did write out a novel on you
goodluck with it all
Take it to Shuan at Boostworx. What's on the sheet? Maybe you could do some of it at home.
+1
Shaun is a nice bloke.
go to the site and send them a Email.
im going to boostworx wed with a list not as long as yours but alittle worse
alot cheaper than jms etc.
good luck
Edited by PREISS
hey mate,
we do this kind of work all the time, we just finished a very major defect on a customers 300zx
we have all the stock parts on the shelf so thats no problem, we can even take the car to regency and get it passed :)
if your still looking for a workshop to do the work let me know and il do my best to help you out
cheers
Steve
Edited by Nisswreck
$250 to issue a certificate for a Hicas Bar??? f**ck that!
Looks like Smooth Garage are going to take care of it next week.
We will see how that goes.
Well that answers the question I was going to ask so you can't have a hicas lockbar without it being engineered. Who did you get the quote from for the HICAS lockbar certificate? If its that much I may as well swap mine back to stock to clear defect and swap back afterwards.
I got that quote from Rory Thompson, they are real arseholes there, put the car in the hoist for 5 mins to have a quick look, I said I was going to think about it and look at other options, and he goes "just give us $30 for our trouble" :)
Yes you better put the stock back on to be safe.
hey mate,
cheers
Steve
PM Sent!
going by your list a lot of the stuff listed it should have been kept on top with if the car was mainted to a reasonable standed .
ie how can you drive and not know you have a broken engine mount things like like oil leaks .
lights not working worn shocky rubbers surley they must have been knocking a bit ?. not meaning to be rude but i see cars like this every day where i work what makes your skyline any better than a vn commy with the same probs .
it may be a blessing in disguise you got pulled over at least you will have a safer car all round when it;s fixed
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
