Ok, im going to change engines on my car, from what ive read i have a few options, can anyone answer these questions:
RB24 - I have a RB20 at the moment. How much would it be to build it into a 24. I have an R34 GTST turbo, what sort of power outputs would be expected, and what sort of ecu mods would be needed? This would be my first pref it could be done for under $4000, but maybee im going to be laughed at for that. Also a aftermarket turbo could be budgeted. How are they for torque? Ive heard they would be happy to rev to 9000rpm?? I guess the only bad thing about this is that i have to buy a 25 gearbox and that will cost alot...
RB25 - How many RWKW would i expect with FMIC, POD, turbo back exhaust? I want more than my 20 has :D
RB30DET - The main problem here is clearance issues.. How much higher is it than an RB25?
https://www.sau.com.au/forums/topic/23961-new-engine-questions-sydneykid/
Whilst using the R34 turbo, id say stick with the RB20 and stock internals. An RB24/25/30 isnt going to really shine unless used with a larger turbo.
What are you wanting to do with your car once its finished???
That should have a large impact on the course you choose. If you just want to go a little bit quicker then id say a slightly bigger turbo that can reliably run 1.2bat with std RB20.
... and you have PM
I'm not sure about the cost of upping it to 2.4L. I'd imagine you'd de-stroke an RB25 crank, or stroke an RB20, but it might be too much of a reach for the RB20 crank, and i'm not sure about what rods you'd need to use as well....
The RB30 block is about 25mm higher than the RB25.
If your using the stock R32 GTSt ECU I guess a remap would be fine for most combinations.
I would go for something very revvy and responsive:
1) Hi-flow the R34 turbo
2) re-map the ECU
3) fuel system
thats if the drivetrain and handling is all good.
-rb25
Its 10.9 psi.
And thats according to the digital readout on the Blitz SBC-iD read out.
When I had the bleeder in there, the stock boost setting was 12psi, the restrictor bumped it up a little.
1psi is not anything to worry about maybe my EBC reads boost incorrect slightly or your guage reads boost incorrectly.
Its 10.9 psi.
And thats according to the digital readout on the Blitz SBC-iD.
The EBC reads boost exactly to the .1 as the Dyno Dynamics Dyno at RPM.
What boost guage are you running? 1 psi is nothing to worry about. :P
With the stock exhaust etc it made 115rwkw dead stock on 8psi.
With the AF's around 12:1 on 8psi it made 125rwkw.
Exhaust fitted and boost bleed it made 152rwkw on 12.5psi.
FMIC fitted and still 12.5psi it made 155rwkw.
EBC and 1bar it made 164rwkw.
The dump pipe isn't really the best as it has a V shape smack in front of the exhaust wheel.
The 3" pipe they used obviously wasn't stretched enough/properly.
That will be going soon.
The reason i wanted to change engines is because my 20 gearbox blew up, and it will only do it again. I could buy the TD06 and a 25 gearbox but that would cost around $5000, plus ecu mods. I figured if i bought a 25, it comes with the gearbox and a bit more top end, and a fair bit more midrange..
I could afford a 26, but how much could i sell the 4wd gearbox for?
Hi Luke, here's what I would do with your budget;
1. Ball bearing hi flow the R34GTT turbo $1.8K
2. Split dump and engine pipe $0.5K
3. Adjustable camshaft pulleys $0.4K
4. Chip R32GTST ECU inc dyno $0.8K
5. R33 GTST gearbox $1.0K
6. If you don't have a FMIC then a standard R32/33 GTR intercooler is the go with alloy pipework $0.9K
6. If you haven't already upgraded the fuel pump, then a standard Z32TT or R32/33 GTR fuel pump is the go. $0.3K
7. You will need an adjustable fuel pressure regulator to stretch the standard injectors $0.3K
For a total around $6K that will give you 200 to 220 rwkw at 1.3 bar depending on the tuner and your engine condition. All the bits are transferable to an RB25DET later on should you want more.
You can make a 2.3 litre out of an RB20 by using a RB25 crank and 4AGZE pistons. To get to 2.4 litres you use an RB26 crank. JOnJOn has done this sort of stuff to an RB20, look up his posts.
For reference, an RB30/RB25DET is 38 mm taller than a RB25DET.
Hope that helps.
Thanks sydneykid, helps alot.
As normal, ive thought of something better. If i bought a 26, how much could i sell the 4wd gearbox for? If i buy the right car i can get one.
The way i want to do this is actually pretty complex, but another 180 im looking at has a kevin kent SR that has 310rwkw. I could sell that engine and buy a 26 with change left over...
I was going to fix the few dents on my car and sell it, as i can get as much for this as i could buy the above 180, plus it has already got tein suspension and full roll cage etc which mine doesnt. All this works out fine with the RB26, as long as i can sell the 4wd gearbox for a reasonable price.. ala 1500ish. So i would have maybee 6-8000 for an engine conversion if anyone has any other suggestions, it just has to be a 6cyl. 2JZ?
Hi Luke, you will still need an RB25DET gearbox and your not going to get 310 rwkw out of a standard RB26DETT. A good RB26DETT complete ready to run is going to cost $6K, plus $1K for the gearbox, $1K to fit, $1K for the radiator, $1k for the oil cooler and remote filter, $1.5K for the clutch, then what ECU are you going to run?
Lat time I costed an RB26DETT conversion there was no change out of $12K with not much more than standard power.
This is a Skyline forum so lets kill the 2JZ idea, the turbo/turbos is/are on the brake master cylinder side. This not good in a small engine bay.
I know that i wont get 310rwkw, but im not fussed if its less. it makes 310rwkw on avgas/tolulene, 260rwkw on pump fuel, but even still, i want something different and a sr 180 is common :).
In terms of the RB26 install i can get an engine/gearbox for $4500
RB25 gearbox for $1400
Got radiator
Sell the 4wd gearbox for how much?
Why oil cooler and remote filter?
$1000 for fit
Not sure if i would need a twin plate clutch especially being 2wd?
It comes with std ecu
Or could i build a tough RB25 for the same money?
What i want is the RB?? in the 180, because its different, light and i like 6cyl turbo the most out of any engines. Dont know what i could sell that comeplete SR, but i would have thought $8000-10000 with everything, ecu turbos etc, so that would be my budget plus a bit more. In terms of power, i want something reliable, 260rwkw or so, and able to be abused sometimes without worrying about exploding.
Hi Luke, let's dismiss the light stuff straight away. Our 1990 R32GTST with the RB31DET in it, is lighter (1140 gs) than the 1994 SIL80 (1160 kgs) with the RB25DET in it. People compare S13's with R33's or R32 GTR's and they are lighter, but not R32 GTST's. I have won heaps of bottles of Jack with bets on which is lighter.
Moving onto your questions;
"In terms of the RB26 install i can get an engine/gearbox for $4500"
I have never seen them that cheap, a running RB26DETT is worth $6K on its own.
"RB25 gearbox for $1400 "
Last one I bought cost me $1.1K. Plus you will need a tailshaft and a speedo drive conversion.
"Why oil cooler and remote filter?
The S13 engine bay is much smaller than a Skyline and there is not as much air moving around the engine. A remote filter and oil cooler is a must for 300 rwkw.
"Not sure if i would need a twin plate clutch especially being 2wd?"
We use a twin plate in 2wd's and a triple/quad plate in 4wd's.
"$1000 for fit"
Tell me if you can find someone good who will do it cheaper and I'll use them. Wiring harness, fuel lines, water hoses, brake and clutch hoses, engine and gearbox subframes, instrument calibration, air con hoses, power steering hoses and reservoir, electric fan and wiring, intercooler pipework etc etc
"It comes with std ecu"
If it's an R32 RB26DETT then that's OK, if it's an R33 or R34 RB26DETT then it's not chippable and you will need a PFC or similar.
As I said it's a $12K job, ask around and see if anyone has done it all up for cheaper.
Hope that clarifies my position further
Why not just buy a 32?
With the type of engine conversion you are looking at there is definately the insurance problem.
Sure it may be different which really it isn't as slapping the RB20/25 in to a 180sx has been done quite a few times.
Tim Possingham at RPM has also done this conversion in a car he did up then sold as he does.
If you like the smaller car i'd say go the 32 GTST and turn it in to a bit of a track car with a 25t g/box rb25 or rb30. :)
In QLD what is the legislation concerning weight vs cc for registration? That might be another hurdle if wanting to use an RB26 or bigger in an S13.
If you want something different throw a 20B in the S13. I cant see the engine being bigger then any of the RBs and they like to rev and like big turbos and knock out healthy power figures.
Std for the factory the 20B has more torque then the RB26, and is cheaper! A 20B S13... is very different.
That would definately be different. I vote the 20B.
I've got an old 82 Mazda 626 sitting unregistered in the driveway incase the skyline blows something. 20B in that thing would be fun. I've seen VN V6's in them. Would be a good traffic light warrior with a supercharged V6 in it.. :D
Sydneykid what have you removed from the 32 to get the weight down, eventually i was hoping to get mine down to around 1100kg, i assure yours is a race car so it has only a single seat and had a cage and youvve remove hicas, a/c, heater all interior.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
