The orig poster is from Vic.
The Vic ruling is from Vehicle Standards Information - (VSI) #8
- The Exhaust outlet must not extend at least 40mm beyond the furthermost outboard or rearmost joint of the floorpan which is not continuously welded or permanently sealed. The outlet must not protrude beyond the perimeter of the vehicle when viewed in plan.
- If to the side of the vehicle, the outlet must discharge downwards at an angle to the horizontal of not less than 15 degrees nor more than 45 degrees and to the rear of any adjustable window or vent. If the vehicle is manufactured after 1988, the discharge must be on the right hand side of the vehicle.
hi again i am from vic and my car height is currently standard height
i do not plan on lowering the car but using a big body kit to make the car look lower than it is.
i will take a notch out of the side skirt wich will be a bit lower than the chassis
im quite handy at glassing and will be looking at modifiying the explosive side skirts that i have in my garage
again thanks for all your replies guys looks promising at this stage
Edited by r33rckt
following that the exhaust will have to exit on the right hand side of the car have you though about how you will route the exhaust?
keep in mind your turbo is on the left hand side of the car...
for street use its pretty pointless as it will reduce your ground clearance (to possibly illegal heights) and draw unwanted attention from the boys in blue.
also IMO cars with bodykits not lowered look just plain ridiculous
Edited by Phobic
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
