  • Replies 57
cranky yea gtst
turbo box
give us a bell if you want it and ill hold it for ya
fair few people wanting it
pete
besides that photos of what people have asked for below
stripping the next few day so speak up isf you want shit
as ill pull it of and get a photo
gear surround
mats
i have all teh ausi seatbelts in perfect condition
boot with wing in good conditio
steering wheel and boss kit needs a clean
rear lights
the other one has the red bit smashed on one light
Mate,
I am looking for both B pillar covers if they are in good condition.. Couldnt tell what condition they were in from the pics. need the clips and drivers side mostly.
Pm me if you can... Thanks.
REVS
nope was stacked at the race track
pete
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
