Finally It Gets Thru Compliance And Is Tucked Away At Home
Great thing about Nur Specs, there's very little you HAVE to do :P
Some new wheels if you feel like a change
might look at a more solid strut brace too
Mostly just upkeep. It's already modified quite extensively from the factory :banana:
You might want to look at a sound system that works in this country, the only other Nur I have been in has GPS that likes to think we're driving in the middle of the ocean...
well despite my handle it isn't a nur, it was a vs II which at 9000 kms got the R1 do over ..
but yeah I get your point.
I like the existing rims. I might get spacers though, thats an easy mod, yes?
And ICE. You are right the pioneer doesn't put me in the ocean but it reboots constantly when it has
a view of the sky, when in a garage it is happy, however ..
  • Replies 56
g) there is a clutch rattle in neutral that goes away when I put my foot in the clutch.
Do coppermix twins rattle? I remember reading they don't. Is it the flywheel perhaps?
it isn't enough for passers by to think there is a problem but it is there.
Awesome car!
Nismo super coppermix twin plate clutches definitely rattle, so thats normal.
Nothing looks tougher than a black gtr, nice ride bro
H ) 1200 is abit high, on my gtr the idle control is under the middle of the plenum, there is a flat screw driver screw go 1/4 turn at a time give rev let settle should do the trick, if not got a gasket leak
I ) Nice rims what size are the tyres on them if they are smaller then fac will put out speedo ( reading faster than doing will make the odo clock up quicker ) 245/45/18 i think are fac the 34 check rolling diameter at local tyre shop.
Car - Amazing - WoW
the only thing i can give advice on is the rattles....i have a r34 gt 98 and i just went through the whole car untill all the rattles wer gone.....just spend a bit of time and if ur brave/stupid enough (not sure which one you would be if you did this to a gtr) you can pull out ur dash and speedo and all the side doors etc to find the rattles...i had to pull my drivers door apart because of a rattle...found a bolt in the bottom of it... :S
good luck with the car
dont touch that beautiful engine!!
Engine ..
What should I do to this car? I'm thinking perhaps doing anything significant
to the engine would diminish it?
Can you stop posting pics of your car.. SERIOUSLY!!!!
YOU ARE MAKING US ALL JEALOUS!!!!!!
STOP IT :)
STOP IT :dry:
i had more than enough aggro and unexpected expenses getting it over here,
and way over 3 months of a wait, plus took the keys on the eve of a worldwide
economic depression.
But ok... from now on I'll just keep it hidden!
Great thing about Nur Specs, there's very little you HAVE to do :laugh:
Mostly just upkeep. It's already modified quite extensively from the factory :D
his car is not a nur doof. it's a v spec II modified by nismo. :)
cheers
I wanted to take some more pictures, including of my questions.. :laugh: but so far they are
a) after an hour on the road the back of the car emits a quiet but annoying squeak.. squeak..
over bumps, eg the damn pacific highway north of coffs. doesn't seem to happen
when cold.
b) does anyone know a great mobile detailer guy, who loves black, in sydney?
c) Should the fuse box in the engine bay have a cover?
d) does every gtr have little dash rattles on bumpy highways? I've got a couple but won't
go hunting for them if thats just the way things tend to be? like, coming from behind the
dash, or air vents there are these little scratchy ticky sounds over bumps. My other car
is a golf and its solid and tight, so maybe I'm expecting too much of a vintage car.
e) the biggie :) The gear stick has what I imagine was very shiny looking aluminium with the
GTR logo but it is all tarnished. If this is a stock gtr gear stick, is there a stock cleaning
product people use on it?
f) when I open the door(s) they don't hold open they just swing as wide as you like and on
a camber will shut again. The door arm looks like it has outdents on it, which i can just feel,
is that something that can be tightened up or is it just the way it is?
h) it idles at 1200 indicated, is that about right? very smooth but seems high.
i) the speedo reads 10% over. I'd rather it read right, is that tweakable?
specs, well, I'll take it somewhere to check it out see what it does on pulp.
it has a nismo ecu, n1 block and all the nismo r parts... an R1 conversion with the
omori plate in the bay (nismo still have the goodies list up somewhere). S tune
suspension and the weldina exhaust which has a lovely popping on the overrun..
A) shouldn't really have any squeaks. could be easy to find, could be hard. worth looking though. could just be some loose stuff in the cabin.
B) don't know anyone really great sorry.
C) yes it should. it was most likely taken off to jump start the car. or taken off when cleaned at the docks. check your boot or glovebox for it. the cleaning guys at AAT are generally pretty lazy. they will take bits apart but not put them back together.
D) shouldn't really have dash rattles at 16,000kms.... my current 34 with 80,000 has none. my last R32 GTR had none either and it was 19 years old with 100,000kms!
E) not sure what to use. but if it's really bad, and it's the standard gear knob you can buy a new one. they are not too expensive and it just screws off.
F) Marss answered this one. yes they should stay open. I'm surprised they've already gone on a 16,000kms car.
G) tbag's answer was only valid for 32 GTR. with 34 GTR they have a getrag box and a dual mass flywheel. if you have an aftermarket clutch chances are you no longer have the DM flywheel. so in neutral with foot OFF the clutch you will get a little "clackety clack" type noise and possibly a fainter grinding type noise. it's due to the combo of the getrag box and no DM flywheel. it's no big deal. just a little annoying.
h) idle should not be that high. around 900 is normal. but will idle up around 1200 when cold. do you know what cams are in your R1 engine?
i) it can be fixed if you like. look up instrument calibration in the yellow pages to find someone who can do it.
awesome car mate. The R1s are a really cool upgrade. Lots of nismo goodies bolted onto it. an R1 modded 34 is right up there with the pick of GTRs to get. now come over to my place and lets play cars! :D
lol, I like to gather them all around me. 34 GTR, 32 GTR, RX7, Silva, and all the parts, then sit there going Broom! Broom!. it's normal isn't it?
thanks, they are 245/40/18 (potenza). I doubt the 40 vs 45 could make a 10% difference in speed though..
Guess I'll add this to a list of minor stuff to get done..
The japanese page is here
http://www.nismo.co.jp/shop/shop/omori/engine/r1/index.html
but it isn't clear to me whether cams are on the parts list ..
Other omori R1 conversions put in 272 degree cams, but maybe not the R34 conversion.
his car is not a nur doof. it's a v spec II modified by nismo. :(
That post is ooooooooooold... and he already corrected me... I don't need it twice :laugh:
But that being the case... NEW TURBOS! MORE BOOST! HEADWORK! SWAY BARS! :P
I could mod a Vspec II, but not a Nur...
Wow Just wow.
Dont spoil it. Im sure nismo did all thats needed for you to have a awesome car that you can just sit back and enjoy. I say leave it modless.
And that engine bay! Perfect.
the fact that you have stated "it's normal isn't it?" .. means i feel normal now aswell.... I thought i was the only one to secretly sit around and play with my cars .. tucked away in the garage..
btw..... that IS one SEXY SEXY car ...congrats and enjoy ..
yep, that's why I asked. it's quite possible your R1 engine has larger cams. I must say mate it's a very cool 34. I'd almost rather it over a nur anyway. it should certainly have a fair bit more power than standard too.
and seriously bring it over one day! lol I want to check it out. and if you would like to know I can probably find out from japan for you exactly what mods have been done to your R1.
You're on the right track, my boy.
J, yes it'll be running Nismo cams as part of the R1 package, so the idle will be a bit higher and lumpier. Don't ask me how I know this lol...
For those who don't know, the R1 engine package (without taking into account the rest of the Nismo goodies on r34nur's car) is an engine-out deal, and, depending on the donor car, is worth $30,000 at current exchange rates. 450ps of RB goodness - effectively a 2.6 litre version of the Z-tune motor. When I have spare time, I'll translate the parts list for the package. Very thorough.
J, I'll put you in touch with my GT-R guru, he has connections in Omori factory who might be able to give you some more history on your car.
Edited by Iron Chef
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
