I'd go the silver one with bodykit and modifications. It also looks as if it's got a decent FMIC there too. You should probably drive the cars first to see how they all feel. The insurance is going to be a pain though, and the extra mods will make it more expensive to insure.
I'm not too keen on red cars, unless it's a Ferrari. I think black or white looks the best personally. Silver is good too, but it's a common colour. I guess you can always get the car resprayed.
https://www.sau.com.au/forums/topic/23970-decisions/page/2/#findComment-517314
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
    • E10, by very definition, has 10% E in it.
