yeah thats a pity about the compliancing, hope all goes well
If you ever go down the importing route again and with the exchange rates i wouldnt recommend it any time soon but Phil's mechanical service in perth is the best. He has never had a car come back from the pits that didnt pass
yeah i would make sure i got it done by someone here in perth if i was to do it again. Though i have to say after all this i dont think i will be doing it again.
Its just far to much stress, waiting and i have already had a day and a half of work which is not really too good, and I am still going to need more time off to go to the pits again.
I just realised i dont need the standard tyres to put it over the pits i need to have 245/45/R17s because thats what i have on my tyre placard. at the moment i have 255/40R/17's on the back and 235/45/R17s on the front.
I called the DPI today and talked to one of the technical expert guys to see what i would be able to get away with and he said i can not have the 235's because you are not allowed to go lower than what you have on your placard.
I am hoaping that i can get away with the 255's and just change the front but im not sure? i could not remember off the top of my head what i had on the car so the guy could not give me an answer but i think i will call again in the morning and see what they say now i know what i have got on the car at the moment.
Does any one have a set of R34 wheels with 245s on them that they would be willing to lend me to get my car over the pits?
have 235 on the front at the moment and 255 on the back.
I think if i get pair of 235s for the back i would get away with it because the front abd back will be even and they will be 10mm under which i think im alowed but i really dont want to get there and have them send me packing again over 10 bloody mills.
thanks.
Got spare 34 wheels here too bud. 99% sure the rears are 245, havnt checked in a while. Let me know asap but coz I fly out to Tokyo this Saturday, but I've got Friday off work and u can just give me my stock airbox and wheels when I get back November 2nd-ish. I dont have ur number anymore coz Monga ate my fone on the weekend. Got the same number but so gimme a txt and I'll reply if I'm not too busy playing Snake 2 on this temp piece of crap.
Edited by Magic
It sure did :P
would not have been able to get it done if it were not for brandons help. And my girlfriend who had to do a lot of the running around for me while i have been at work.
now it is just a matter of trying to get the car all cleaned up. and getting the big yellow egg stain of the back :D
No worries man cheers for the vodka. :ermm:
Saw this thing tonight. Looks really mean for a white 34, and WedsSport wheels look nice on it too. Sweet ride. Woulda def been worth the wait. ;)
Thanks m8
yeah im really pleased with it. a few things i want to change and sort out with it but all in all i think it worked out to be well worth it.
have a good trip m8 and we will have to catch up at some point wen you get back.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
