ZILLAR5 Posted October 11, 2008 Share Posted October 11, 2008 ok this is really driving me nuts i'll be driving along at 100km and all of a sudden it will go in and out of overdrive, in - 2650rpm .. out- 2900rpm usually when its warm. Other times i'll be driving normally and it will change down from 4th - 3rd without touching the accelerator? i've searched the forum some say it could be the alarm causing it, i did get an alarm installed around the time it started? another says to clean the plugs/sockets near the wiper bottle under the bonnet, trying this now. Could the TPS be out of whack? i've had it off to clean, have i put it back in the right position? Thanks in advance Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/ Share on other sites More sharing options...
ZILLAR5 Posted October 15, 2008 Author Share Posted October 15, 2008 anyone? btw i've taken to transmission shops and they all say it fine? Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4197348 Share on other sites More sharing options...
Detour Posted October 15, 2008 Share Posted October 15, 2008 anyone? btw i've taken to transmission shops and they all say it fine? that happens to me exactly. It wont stay in overdrive especially when driving on 100km (car is warm) it goes from approx 2500 up to about 4000 revs then whenever it feels like the overdrive kicks in again. I spoke to my mechanic and he said to me that my gearbox is slipping. He also said that when it revs higher push the overdrive button on and off and see if it will help when driving at 100km or when it revs higher that its suppose too. hope this helps Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4197547 Share on other sites More sharing options...
White GTS-T Posted October 15, 2008 Share Posted October 15, 2008 (edited) Have had two cars recently in the workshop, both presenting with the same aforementioned problem. Both, I'm sorry to inform you, had to have new/recod transmissions fitted. Not going into/staying in overdrive. When the converter starts to slip it heats the trans fluid massively and the trans fails.If you smell the trans fluid on the dipstick it will smell burnt regardless of colour. Unfortunately servicing the auto wont accomplish anything. I drove along with the scan tool displaying current data and manually put it in and out of overdrive and nothing happened. The first thing i would be doing is getting the car onto a scan tool and go from there. Let us know how you go, good luck. Edited October 15, 2008 by White GTS-T Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4197662 Share on other sites More sharing options...
Basti Posted October 15, 2008 Share Posted October 15, 2008 same here Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4197923 Share on other sites More sharing options...
d_33vl_1 Posted October 17, 2008 Share Posted October 17, 2008 hey mate def sounds like converter slippage... whats you location.. if in melb can give you place to go Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4202713 Share on other sites More sharing options...
ZILLAR5 Posted October 18, 2008 Author Share Posted October 18, 2008 yeah d_33vl_1 i'm in melbs thanks for all your responses guys Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4203566 Share on other sites More sharing options...
mid life crisis Posted October 18, 2008 Share Posted October 18, 2008 i had exactly the same prob with a nissan patrol similer box cost me a rebuild in the end it just started doing more crazy shit as time went on Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4203623 Share on other sites More sharing options...
Basti Posted October 18, 2008 Share Posted October 18, 2008 yeah d_33vl_1 i'm in melbsthanks for all your responses guys me too. im interested d_33vl_1 Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4203796 Share on other sites More sharing options...
~R33AzzA~ Posted October 22, 2008 Share Posted October 22, 2008 +1, d_33vl_1 Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4211392 Share on other sites More sharing options...
Basti Posted March 10, 2009 Share Posted March 10, 2009 went to knox automatics. turned out to be the solenoid. 400 bux to fix and service. dammit Link to comment https://www.sau.com.au/forums/topic/239747-r33-auto-wont-stay-in-overdrive/#findComment-4468407 Share on other sites More sharing options...
