Finally nice weather, and time to burn,
so this is what I did today.
more here if you are interested
http://noddle.110mb.com/Megasquirt%20II%20v3.0/index.html
still tuning it, using the self learn feature with my wide band, to get it close,
I must say it's a steep learning curve, since i haven't done anything like this before.
Nigel
Edited by noddle
https://www.sau.com.au/forums/topic/239767-megasquirt-ii-v3-and-my-240k/
How's the tuning going Nigel?
Has it made much of a difference to the car?
Hi Andrew,
Since the motor is still dead stock, the only difference I have noticed, is that it has just a little more torque, the reason I know this is that were I like there is a hill, that when I drive up it in 4th at 60ks, about 2/3 the way up it, I need to go back to 3rd, or it drops back to 50ks, but with MS It sits at 60 all the way, I know, not a lot better for the expense.
But When I bolt on my turbo (the reason I brought MS), I will be able to keep the AFR where it needs to be, and not lean out.
http://noddle.110mb.com/Turbo%20Upgrade/index.html
But my next step is to install EDIS, so I can control spark (my dissy's vacuum advanced is stuffed)
http://noddle.110mb.com/EDIS/index.html
Still have lots of little projects on the go.
Nigel
good stuff nigel!
beat me to it haha!
i have to put mine off for a while.... leaking radiator (yay) will look at alloy S13 item for replacement
I'd recomend getting a radiator out of an EL koon car - bigger and better from a 4lt and cheap as from any wrecker
  • 2 months later...
Finally,
I have EDIS running with Megasquirt, in the end it was fairly easy to setup, just some nerves, (not wanting to fry my Megasquirt, you just need to follow the directions, and check what you have done for mistakes)
more pics here
Nigel
Edited by noddle
  • 1 year later...
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
