The only thing you have to worry about, apart from the tyres sticking out of the guards is rolling diameter.... you can go +15mm or
-26mm
Pages 10 and 11 has the info.
http://www.transport.qld.gov.au/resources/...r_vehicles2.pdf
and to calculate u can use..
http://www.dakota-truck.net/TIRECALC/tirecalc.html
I might be totally wrong and probably am lol but i didnt think you were allowed to increase overall track by more than an inch. Don't even know if the GTR rims will do that, but might be worth looking into...
I was thinking of doing the same thing to my GTT so would be keen to know if it is ligit!
PS drift barbie - I have an aftermarket ecu, what were u wanting to know? and yes i know u werent asking me :P
The problem you'll have is that they do protrude ever so slightly from the front guards.
lowering, camber + skinnier tyres will fix that :)
But yes as someone mentioned above, as long as OD is not more than 15mm and wheels/tyres do not sit past the guards you are fine. This is for QLD.
You will however find a large majority of hardcore wannabe drifters think of you as a softc*&k for asking the question though because to them if its not hella flush (wheels stickin 50m outside the guards) you are an epic fail.
I've seen plenty of 34GTTs run 34GTR wheels....legal or not legal depends on the mood of the day. I would class it as very mildly illegal.
yeah pretty sure you can't go wider than 30mm from the standard tyre,
bingo...
You can increase the diameter of the rim as far as you want as long as its no bigger than the original OEM delievered diameter including the tyre...
The statement below is true also when refering to the above line... This is the max varience allowed when changing the profile of the tyre to suit...
you can go +15mm or
-26mm
col, i think he may have been meaning the width of the tyre, rather than the diameter. the widest you can go is 1.3 times the widest option stock tyre that was available on that car. so even if the car came with a widest optional tyre of 225 you could still run 285 tyres (1.3 x 225 comes out at 293 so you could probably get away with 295s)
the other thing you have to take into account is that changing in your track. you can increase the track by up to 26mm, but can't reduce it at all. so that means that gtr wheels won't actually be legal because they have a lower offset. and before people start saying that they came on the same generation car, the gtr runs different track to the gt-t. the front is the same but the rear is different (it's wider), so putting the gtr wheels on will reduce the track. however if the gtr is listed on the same tyre placard (sticker just inside the door) as the gt-t then you could get away with it.
Sorta, I didnt explain myself very clear... But in short you can run 17" rims on a car that came out with 14's if you want...
As long as the overall diameter of the tyre is no bigger than the OEM product...
As there is slight difference always the DOT came up with a suitable legal variance...
you can go +15mm or -26mm
I stated 30mm, meaning an R34 GTT can run up to 255 without being much of a problem in terms of sticking out etc...
That said however it depends on the size of the rim as the profile size will change the first number factor...
As for width yes there are some loop holes as to running even wider rubber, however there are other factors that usually stop you from doing so...
You cant run rubber wider than you guards, if it sticks out its illegal (hence offset of rims is so important)...
Also I should point out the rubber sticking out is really down to the kindness of the officer as to whats right and whats wrong. Ive heard of a VE GTS (stock rubber) being booked by police in QLD for having rims and tyres that are aparently illegal by DOT standards. These were factory fitting rims and tyres, so even if legal cops can still put you through the hoops if they want...
The legal line is quite clear in here as posted the other week...
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
