Hey guys,
How do you get rid of the mist/fog on your headlights. I've got xennon's on mine and I can see white fog/mist on the plastics. I thought it was on the outside but it appears on the inside. When i go wash the car they disappear but after 10-20 minues they come back.
I know it's an inherent thing with Stagea's but I would like to fix it and keep it clean (man why Nissan couldn't make it glass to save us some time and the headaches)
https://www.sau.com.au/forums/topic/239796-xennon-headlights-mistfog/
i remember spoting something at supercheap to fix this. it involves removing headlight, pouring in the liquid and moving the light around so all the area gets covered and voila. 1 shinny new looking piece of clear plastic apparently...
I took mine off and took them to a plastics shop where they sanded them back with a very fine sandpaper and then buffed them. They came up great, made them clearer at night and the only thing wrong with them now is the ageing cracks on the inside of the plastic cover. Best bet is to do what the others have said and use a plastic polish, or if you have access to a buff, you could always try sanding and buffing.
Use meguiars PlasticX plastic polish and then protect them with PLEXUS.
i can vouch for this, my old 33 headlights went crappy as they all do, used the PlastX on them, and they came up like literally new.
even ScratchX will work if you have that.
Looks like i'm going to go find some PlastiX and Plexus - where's the best place to buy them from??
RBPOWA - Use it on the outside, most people say it's on the outside where it fogs up and it would be a pain the in you know where if you had to do that on the inside
As I said before why didn't Nissan use glass instead of plastic...we'll never know
I usually get my plexus from marine chandlery shops, great for tail lights as well (originally designed to protect plastic aircraft windscreens). PlastX was harder to find, ask at supercheap maybe.
For those looking for a cheap intermediate solution (while trying to hunt down the above mentioned products)...try using toothpaste. Most toothepastes are mildly abrasive - enough to "polish" the headlights. DO NOT get it on the paint (or anywhere except the plastic headlight) obviously but it will clean up the plastic headlights fairly well if you use a bit of elbow grease (and wash it all off afterwards). I've done it a couple of times before and it works ok - not as good as meguiars PlasticX plastic polish but may be all you need.
WARNING: try it on a small patch of the light first to make sure it works on your car. (end of disclaimer).
brasso works too. ive used it on mine. it got rid of the yellowish hepatitis tint on the headlight :banana:
you hardly have to rub. just apply a small amount on a rag, rub over a small area, give it a minute to dry, and then wipe it off with a clean rag.
i cant compare it to plasticx etc. but it works pretty well for surface issues.
sorry to hyjack ur thread but does anyone have any issues with moisture getting inside their parking lighs on their s1 stags? My passenger side does it and it looks crap IMO. Any ideas on how to fix? I tried some windscreen glue but obversly didnt get all the holes or leaks... any other ideas?
do not use tooth paste . sure it is abbrasive and will polish things BUT unlike actual polish it has no control over the size of the grinding particles . think about it . and dont use it on glasses and cds and everything else someone who thinks their clever has told you
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
