  • Replies 108
I believe the R32 GTR still holds the top speed at bathurst of over 300kph.
The Mines car is a road car converted to time attack and it runs on treaded tyres.
A V8 supercar is a purpose built race car with virtually no original Holden or Ford parts, unlike the Group A days in the 1990's where they were based on modified road cars. (Look at the VE Commodore Supercar, the rear doors are even cut shorter to fit V8 rules!)
Having said all this, I belive the Mines Gtr with SLICK TYRES would be faster around Bathurst.
To give an example, I race at Barbagello in a Series 6 RX7, we are doing mid 61 second lap times, the V8 supercars are doing 58's, thats 3 seconds per lap difference. The series 6 is running on 225/50/16 treaded R comp tyres (similar tyre as Mines would use) the V8's run slicks, If you put the same slicks on the Rx7 the lap times would be very close. The RX7 was a road car converted to track car with the normal mods like roll cage, suspension, brakes and HP abour 400 rwhp. It is nothing special just well sorted.
The V8's are good for what they are, A big heavy car on a smallish tyre, they are reliable and consistant, they run fast laps at Bathurst for 6 hours.
Dont forget they Banned all turbos because they were embarasing the V8's on their home ground. If Nissan built a GTR to race Group A again the V8 supercar would see its tail lights for about 5 seconds then it would disapear unitil the GTR Lapped the V8 again.
Here is some incar footage from our racing at Barbagallo
There's only one way to settle it - we get some booze, we appoint a bookie, we get a remote control car of each, we head down the local tennis court and duel it out.
Does it matter? Not likely any of us are going to be in the market to buy either??!
:spank: well said :wave:
The R32 GT-R was banned because the Falcadores couldnt catch it. It was proved 18 years ago that the GT-R is faster!
WRONGGGGGGGGGGGGGG
Group A racing was phased out worldwide because it was too uneconomical
the gtr was never banned
people need to learn facts
i know nothing of the rules/regulations of bathurst, or really got into it at all.
but... this bloke i used to work with who claims to be a bigtime v8 supercar freak said that they brought in a rule that outlawed Electronicaly fuel injected cars and that they had to have a carby? is this why the GT-R was phased out?! or he babbling some smack to me. haha
cancel that jus did my own research
"This class banned turbocharging along with four-wheel-drive, and effectively banned Nissan's GT-R from competition. "
thanks wikipedia :)
thanks wikipedia :)
uhh.. if you read 6 posts back, you'll find your answer...
group a racing was the top echelon of racing way back when
pretty much unrestricted engine size, power, engine capacity, 2wd/4wd etc etc etc
as a consequence there were really fast cars and cars that werent so fast
that my understanding why GrpA racing was canned (like gary said - uneconomical and too vast a difference between the good and the not as good)
the japanese GT500 and the aussie v8 supertaxis all stem from the GrpA - but restricted engines, engine capacity, production based cars (so no 4wd supertaxis) etc etc
somebody correct me on teh finer points of it, but that to me is the general gist of it
group a was a group of racing for modified touring cars, but was phased out as gary mentioned, and in australia was replaced by the 5L v8 supercars, and 2L super touring cars.
edit... yeah, what ash said, everyone basically went their seperate ways, and we ended up with supertaxi's.
i'd still have one, cant go past that v8 note.
ok we can say that the r34 would be a good competitor anyone who knows anything about jap track cars would know the mines r34 would give the V8's a hard time for a 7 year old car against cars that are a year - two years old but! how about we change the rules i can bet if they put on the new r35 on that track it would tear thoes v8s a new A hole without a doubt it did it with the r32 it can do it again.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
