Hey,
I've been meaning to do this for along time.
Now front bumper is off and i'm at the BOV stage.
Switching back to the standard bov's.
I noticed on the standard bov' there was the hoses/outlets that came out from it into the black pipe that ran across the front to the other side. I don't have that pipe anymore due to the FMIC.
What do i need to do to replace the hks bov's with the original ones?
hoping to get it finished today :)
So any help asap would be great.
Thanks
if there are existing threads, please pardon me and direct me, i am so noob at the search function that it comes back half the time without results :S
Edited by Owgasm
https://www.sau.com.au/forums/topic/239822-bov-from-hks-ssqv-back-to-stock/
Umm, yeah, i've got an idea of how the original piping was set up. Will i need to reconnect the original piping? I removed all original piping in that location for the FMIC.
The original BOV piping is still there as the HKS ssqv just had adapters and they just bolted on.
No way around it with using stock BOV's?
Anyone got a photo of there front bumper removed - R32/33 GTR.
Might sell the twin ssqv, but first i need to get the original back on.
Any help would be greatly appreciated :ermm:
Edited by Owgasm
Thanks for that.
So all those running stock bovs with an aftermarket fmic.
Need to run the recirculation pipe as well?
No way around this?
Hey,
If you want to run the recirculation system then you'll have to make up a
replacement for that pipe that _does_ fit with your cooler and goes back to the inlet
side of your turbo(s).
Alternatively, the stock BOVs can be vented to atmosphere if that's what you want to do.
Just leave the pipe off. The other side will need to be blocked as well if it's not already.
Some people have reported leaks at idle, but it will cost you $0 to try it and see whether
it suits you or not. You probably want to fit some type of minimally-restrictive filter
over the BOV outlet to stop crap getting in there if you decide you like it that way.
Or leave the BOVs blanked off (or remove them entirely) and put up with the extra noise.
Regards,
Saliya
Hey,
Thanks for that.
First option of a new recirculation system is a no can do (i'm too lazy).
The atmosphere bov thing you mention is a possibility. The other side (opposite to bov's) has been sealed/not in use.
What do you mean by "leaks at idle"?
How bad is it? What does it effect?
Other than the idle problem, are there any other problems?
What material have other people used to cover the outlets?
Thanks for the great information.
Was desperate today and put the bar back on so i can drive it tomorrow, but its easy to take off and put back on, just this time i need to know what i'm doing.
Thanks in advance :)
Hey,
Thanks for that.
well, the laziest option is to just leave the existing HKS item(s) in place.
I haven't done this myself - when I put my oil cooler in, I removed the stock valves entirely.
Do a search for 'gtr bov leak' and you will see what I mean by 'some people'.
A atmospheric BOV opening on an AFM'ed car under boost dumps measured air, when this happens the car runs rich.
(black smoke and/or flames on a gearchange). But you have this problem already :bunny:
If it happens at idle, where you only have atmospheric pressure pushing air in (no boost) you don't know which way the
air will flow (out the BOV, resulting in richness; or in the BOV, resulting in unfiltered, unmeasured air entering
the inlet tract). Either way you upset a fine balance (idle) and this can cause stalling. Aftermarket VTA BOVs like your HKS
usually have an adjustable spring that amongst other things allows you to make sure the valves are closed at idle.
Once I saw a person replace an air filter panel with one of his mother's stockings, so I don't think the answer to that question will be useful :(
Best thing to do would probably be to get one of those K&N filters of the correct diameter (they make them down to real small sizes)
and clamp it on the end of the 'Y' air tube (says 'point 5' in the diagram) attached to the BOVs. Or get two if you don't have the Y pipe.
I would try it out unfiltered first, and see whether in your case there are extra problems caused (e.g. stalling) that you can't live with.
Then if you decide you like it, go buy filter(s) to suit...
Regards,
Saliya
Still running the ssqv's, really don't want to take the time to change back to stock and not re-circ and possibly get problems.
Has anyone got pics of how the re-circ pipes goes through the front.
Is there any way to run the original pipe through the front somewhere.
Are there really no other options :laugh:
What other people that have FMIC do with there re-circ pipe? Do they do whats stated above by Saliya?
:cool: HELP.
I've got a funny feeling i'm loosing power every gear shift when i'm not going crazy with the car.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
