I've noticed that my dash clock runs fast by about a minute a month... it is just really annoying. Seeing that the timing is regulated by quartz, i can't understand why this might happen...
Has anyone noticed this? I discovered it as about 3 months ago i installed a new head unit, and set both the dash and head unit clock to my watch. The h/unit and watch still read the same, but the dash clock is fast. What is the deal? am i just going mad???
:confused:
Originally posted by Shell
haha never paid that close attention to it really...
i never have it on the right time anyway, I put it forward by 5 or 10mins cos I'm always running late :P
right on its the only way to be on time or just a little late to work rather that an hour late every day hahaha i have the same lateness disease
Originally posted by T0nyGTSt
It's Japanese time bro.
E=MC^2
When you run f00l seek times, the real world slows down but time in the Skyline cabin speeds up.
Pay attention in physic class.
T.
ROTFLMAO:bahaha:
Originally posted by Spooks_Skyline
yup, fair call
my clock is always fast, regardless of what time i set it to;
doesnt seem to get past 10 minutes fast though . .. .
Simple solution - set the clock 10 minutes slow. Then eventually it'll be right and you'll never have to touch it again :P
Yup Tony nearly got it right. :uh-huh:
The smart buggers at Nissan had this figured out. The Skyline clocks have a built in auto-relativity compensator. The system calculates how much to slew the clock to compensate for speed/time.
The faster you go, the faster time will pass outside the car. It will seem like a shorter time to you and the povo clocks inside the car.
Your watch and head unit would not have this feature so they will always be slow.
:P
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
