nissan s15 2000 model jap spec
manual 100,000 km
sun roof/ all option
alarm/ central locking etc just installed
kenwood cd player and clarion speakers
vertex kit
vented bonnet
custom FMIC
BRAND NEW volk GTCS 10's and 9's havent been driven on yet
silk road rma8 coil overs base height adjustable/ camber tops etc etc ( brand new)
silk road camber arms (brand new)
origin tail lights
origin boot lip ( carbon)
exhaust tech dump pipe
exhaust tech stainless dump back to jun bl muffler/ twin tips put on yesterday $880
white line front and rear adjustable sway bars
trust shifter
orc 409d silent single plate clutch and fly wheel (brand new)
trust filter
apexi power fc and hand controller
greddy profect b boost controller
trust turbo timber
both in custom carbon fibre din pannel
walbro fuel pump
new battery
candy apple red/silver rocker cover
all parts are pretty much brand new. 6 months rego has just been put on today.
tuned by boost worx
$31,000 ono
This been my project for along time now and dont have the money to keep funding it even tho its almost there!. guards and it would be finished. i know ill regret it but its too hard to keep on apprentice wages!.
phone: 0423697701
https://www.sau.com.au/forums/topic/239901-tuff-s15-allmost-finished/
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
