  • Replies 51
nice buy mate! :)
but seriously, those lights need to die in a fire. as for wheels, meh, so what if everyone has doriteks, they look decent and they fit, so why not? and damo has a set for sale for fair cheap, so it might be worth looking into.
1998 is probably compliance date
nope, engine capacity - 1998cc is 2L
sorry if it's been pointed out.. cbf reading whole thread :)
buy these, much more sexier than doriteks ;)http://www.nissansilvia.com/forums/index.p...p;#entry4573927
Edited by M I K E
sorry if it's been pointed out.. cbf reading whole thread :D
buy these, much more sexier than doriteks :)http://www.nissansilvia.com/forums/index.p...p;#entry4573927
Its an SR, so it fits?
Yeah, those rims are baller :P but would look good. Dont buy my rims unless your planning on a brake upgrade, lol
Edited by Damo_R34
Yeah, those rims are baller :D but would look good. Dont buy my rims unless your planning on a brake upgrade, lol
every second person that gets a new sr s13/180sx thinks the build date is 1998 over on ns.com :P
Edited by M I K E
I guess I fit into that noob section :)
Just checked, it is 1998CC (stupid me) and was made 1995/07. I never really looked too closely at the plate and it was the previous owner who pointed it out to me and said it was the build date.
Rims are still a while off, hardly have enough money to pay for stamp duty OR insurance!
First will probably be side window visors, head unit, Type X spoiler, and either tint current lights or get Type X lights. Not in any particular order.
I just need to wait for my bank account to build back up again.
PS: I love my car.
Hey Nathan, I got it sorted, what I thought was the year was just the engine capacity. I was told it was the year but didn't look close enough. I did FAST it and that matches the 95/07 build date I found.
Damo I just like the looks of them. Not sure how/if it'll effect driving or vision, but I love the looks of them, as long as they're the proper ones (and not just the simple fold over type).
Not like you can see much, but I know there are some dodgy ones, I like this kind:
Edited by Thomasino
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
