Hey Nathan, I got it sorted, what I thought was the year was just the engine capacity. I was told it was the year but didn't look close enough. I did FAST it and that matches the 95/07 build date I found.
Damo I just like the looks of them. Not sure how/if it'll effect driving or vision, but I love the looks of them, as long as they're the proper ones (and not just the simple fold over type).
Not like you can see much, but I know there are some dodgy ones, I like this kind:
haha, well ok, thats different, usually for old people who get too hot when its raining and dont want their interior all wet.
  • Replies 51
I think it derived from the "JDM modders" over from the Honda groups, aus delivered Hondas dont get some stuff but Japan does; if its factory fitted over in Japan its zomg JDM must have it! Its one of those little things that sets off the car when accumulated - window visors, foglamps, indicators, headlights, tail lights, antennaes and so forth...
Mine came with window visors... GG :P
should have said something in the forums when you got it haha, i just got my r33 on the road on thursday, so was doing much the same (driving) spent quite a bit on fuel, don't mind saying haha.
either way looks nice and clean mate, good buy
Edited by d--
Yeah Daniel too busy driving it around and getting used to it, mainly learning manual. Picking up on the small things which results in a smoother drive and less injury to the neck (or spillage of the drinks haha).
I went to get a haircut today only to find the barber shut, so instead of going straight home decided to go for a bit of a drive along the beach between seacliff and Jetty road Birghton before going home, just for the enjoyment.
a good place to go for a drive thats not too far out is head up to blackwood and then just follow main road out down past belair through windy point, drive as hard as you feel safe with and just go for a nice downhill drive, windy roads but still a great drive. (it's where i'll be tonight :dry:)
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
