Hi,
I'm getting the 'mod' jitters again lately and was considering a fmic.
Basically running a SII R33 only mods are turbo back exhaust (split dump, hi flow cat, trust pe2) and a k&n filter.
Was looking at FMIC and boost controller next but was wondering if there are any 'stealth' fmic that will sit under a stock sII front bar which offer good performance??
Any info or pics of what you have done would be great
cheers
https://www.sau.com.au/forums/topic/239922-fmic-for-stock-s2-front-bar/
Hi there also looking for a fmic that will fit nicely behind s2 front bar. I here there is a place in hoppercrossing melb vic that supply a turnaround one as well that fits nicely. I forget the name of the company but thinking about getting one from there. They are also on this forum look in parts for sale section (traders).
thanks for the replies guys.
ok prob bad wording. don't mind a bit of modding to stock s2 front bar. This makes option easier?
keen on seeing pics of what ppl have done and what running.
Found this via google... kinda like the look of what is on it but have no idea what it is or how much modding to get it to fit! http://s134.photobucket.com/albums/q95/mrl...nt=MobyDyno.flv
http://s134.photobucket.com/albums/q95/mrl...ent=mobyimg.jpg
Edited by MAS_R33
Lith's intercooler is just a standard "over the radiator" type.
This is mine:
Its a Blitz LM Kit. Fantastic little piece. Cant be happier.
Note i screwed up the cut a tiny bit on the passenger side, thats why you can see the pipe :) Had a slightly bent bumper iron that i didnt know about when fitting. All fixed now, but after i had trimmed!
But, if you dont screw it up ( :P ) then it looks great!
Edited by gotRICE?
Thanks for the replies.... also thanks for the pic GotRice. Silver R33 is exaclty what i wanted! >_<
I'm not planning on doing the install myself so might talk to the shop and get them to talk me through whats there and exactly how much of my stock front bar needs to be cut.
got rice my car is a splitting image to yours...... how much did you have to cut of your bar? what needed cutting? can you send me more pics of the install or not?????
cheers
These are the only install photos i took. After a bit of frustration i stopped taking snaps :rofl:
Bumper Iron:
Unfortunately i didnt get any photos of the trimming of the bumper itself, as it was pissing me off :), a fair whack of it is cut away, like, nearly all of it. It takes a long time with alot of test fitting, marking, cutting to get it sitting perfect.
And you also need to severely mod the indicator on this style OEM bumper too. Theres barely anything left of it, and the bit of the bumper it slots into was also cut out to clear the intercooler pipe.
Cutting the plastic holder, pulling the brass connectors out etc... you will figure it out!
x 2
I have this one on my car, with a stock S2 bar you won't have to do anything to the foggies or indicators. You need to trim some of the bar on the passengers side under them though. Nothing major. I installed in about 3 or 4 hours over a few beers...
Big tip, bolt it all together, get the pipes sitting properly THEN tighten everything :rofl:
Edit: This type of S2 front bar http://farm3.static.flickr.com/2093/203340...6708a35a8_o.jpg
Edited by Finchy33
If you arent going to upgrade your turbo anytime soon, then why not just get the r34 side mount.
Its capable of supporting 210kw. Direct fit with no modifications!!
I had mine for about a good solid year with no problems. Even been on track days and no problems with heat soak etc.
Will cost you 100 bucks max :rofl:
Thats another option for you :)
gdluck
i wouldnt bother with a side mount
once you turn the boost up and crank up the exhaust i believe the side mount in the side locaiton is a just a big heater panel
i dont believe you get the gains you get from a decent core in the front of the car
ive got a 450x300x75 core and it fits fine, some of the side bar on the s2 bar to be cut back but it fits well
im yet to see in and out temps from a side mount in the side location
i would expect the outtemps after the core arent that crash hot (mind the pun) when 12psi, full exahust and usual GTST mods
for the cost of typical china cores fitted (sub $500 fitted) why would u bother messiing around with side mounts and junk
ok...I never considered a r34 smic. Basically longer term im wanting to running higher boost on the stock turbo (exhaust is already done).
As car is a daily and reliable driver i want to keep it that way, so thought FMIC would be sensible in first step before mucking around.
Finchy33. My front bar is the same as yours. Any chance you have front on pics? I'm liking what your saying about the minor trimming only.
thanks
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
