:P once upon a time there was a.......................................
Squashed bunny on the side of the road .................
So? I have 4 pages of topics I started .... I'm a whore so what? :banana:
https://www.sau.com.au/forums/topic/239966-damo_r34/#findComment-4191493
Im here because it was reported. Should be busy working. :S
http://www.skylinesaustralia.com/forums/se...ult_type=topics
+1 for damo
You usually make a new thread every so often which is a tad pointless. Most really are just wasteland type posts.
But meh.. I careless which is why I have not bothered moving or deleting them.
If you feel the need to tell all via a new thread about your Divorce, An Offer I Couldn't Refuse!, A Slight Change In Plans!, I'm Back! then really thats your prerogative. Personally I just ignore them and and think bah another thread by Ruby. lol. :banana:
But this thread. its closed. Its a waste of space.
https://www.sau.com.au/forums/topic/239966-damo_r34/#findComment-4191508
Guest
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
