Hey Anyone Had To Replace There Radiator Drain Plug?
just about to get my 32 GTR back on the road for the sunny weekend and what happens stupid plastic radiator drain plug crumbles in my hand! now i have to drop the radiator get all the shitty plastic out the thing and then find a new one somewhere.
so anyone know where i can get a r32 gtr radiator drain plug or at least somethin that will plug it. i was just gonna use a bolt with some tefflon tape and an o ring so it doesn't break again but i have to go find one that fits? any suggestions?
cheers
Dion
probably less effort just to block it off
also a good time to upgrade your radiator!
my mate got a 3-core radiator and there was not enough room to pull the plug out haha
Edited by gfunkk
LOL the exact same thing happened to me.. had to pull everything out and actually shake the radiator upside down LOL. Well, it's funny...... now..
Luckily I stole the gazelle plug until I could get to nissan.. it was like $3 or something stupid
Pretty sure the 180sx, gazelle and r32 gtst are all the same size from memory
hey i have a winner! bolt is a 12x1.25 i used that with a bit of lpg gas safe thread tape for a good seal and also the bolt has to have a head on it to get an O-ring in there. i will let ya all know if it doesn't hold up but works wonders so far.
catch
Dion
Thats a top idea Darrin oops im mean Dion i will remember that for future use
Cheers :O
Bloody JAFA'S
yes it was an awesome idea i thought of it all on my own! even though i am Just Another Fu$%#N apprentice.
you got an issue? then we shall have a duel meet me by the town square with your light saber at noon!
I waited till 2! Where were you hiding under you bed i bet. Your lightsaber is no match for the superior power of my oxy torch
you better stay away from vices for the next week cya JAFA
yeah sorry man got back from teachin at jedi academy and princess leah wouldn't let me go out for a duel. my bad bro
next time
:thumbsup:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
