I called TransportSA recently when I was defected. I was told they no longer issue these permits. I had the girl confirm it with her manager, he said as your car is technically still not roadworthy it can't be driven and that loop hole had be closed. Looks like they lied to me those pricks.
Haha dude, you get different stories from each staff member in Transport SA. I got a permit once for the GTR ages ago when it wasn't registered yet, and the girl behind the counter told me I was not allowed one due to having no registration. After arguing with her and then her manager, I was allowed the permit (I was transporting the car to and from a mechanic - the car had a compliance plate, so it's fine). But she said "you're not allowed to stop the car anywhere along any roads or turn off on any other roads unless specified here" and I said "What if I had to go to the toilet and had to turn off?" she said "No. You cannot turn off onto any other roads".
Yet a few weeks later, I got another permit and put down all these different stops and roads and never got questioned... he even gave it to me at a super cheap price (must have gotten it wrong somehow).
Transport SA have no idea. Just go there and cross your fingers that the muppet behind the desk actually knows how everything works. Just try waiting in line at Service SA in the city and you're bound to hear a handful of complaints from angry people saying "But on the phone, I got told..." and "I want to speak with your manager! No! I will write to my local minister about how shocking your customer service is!".
https://www.sau.com.au/forums/topic/239990-tow/page/2/#findComment-4194023
you're allowed more than one stop as long is it listed in your route and as long as the stops are related to the vehicle's repair or final destination.
Laws changed not long ago regarding permits for unregistered vehicles possibly due to constant CTP issues
https://www.sau.com.au/forums/topic/239990-tow/page/2/#findComment-4194120
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
