Most mechanics should be able to do it.
Best bet is to jump on a 350z or G35 site or look up Nissan USA TSB's for the 350z or G35 and you should be able to pull up a complete workshop process including all the parts needed.
From there most ha;f idea mechanics should be able to do it. Or there's always your local Nissan place, just don't expect them to know what a TSB is :-)
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4192358
cheers guys, would prefer someone who knows and have done this before, rather than they fiddle around with my car trying to figure out wat to do...
thanks bobby for the link, looks like the bearing n axle joint need to be replaced, i thought a simple lubrication on the joint would get rid of the sound.
Edited by GEXer
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4193362
No worries, It's funny though that you simply replace the same parts. I'd be a bit worried about it doing the same thing again. Unless they're now using different bearings or something.
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4193378
  • 1 month later...
  • 5 months later...
Hey guys just noticed a click coming from the back of the car when I take off from standstill quickly and if I then back off the gas suddenly if the car is under load. Only just noticed it because I normaly have my windows up and the air con on + the nismo cat back make its hard to hear things going on outside
dosent sound too bad, If i leave this for a while is anything bad going to happen?
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4604071
Take the TSB down to joshua @ Pro Concept Racing in West Ryde or to Power Play Imports @ Drummoyne
only 2 places i would trust with my car!
+1 to Josh @ Pro Concept - good bloke & knows his proffesion. My car gets milked by josh's 10 fingers.. and i say he does a top job.
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4604111
Relax people i investigated this noise a long time ago however i haven't performed the procedure on my car yet, next service.
Replacement of parts is not necessary other that the bolts and washers. Give this to your mechanic to prevent him from stuffing around. All that needs to be done is have the axle retorqued and greased where shown on the diagram.
axle_clicking_noise.pdf
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4605410
I have one other question to ask which has nothing to do with the topic however i think it is important that everyone knows.
There is a common problem with our cars in relation to the rocker cover (other name for this is valve seat). My mechanic performed a replacement of the spark plugs and at the bottom of the tube there was evidence of oil. It was on the second bank (when you face the bonnet on the right hand side. The spark plug closest to the firewall had the leak. Has anyone noticed this yet?
Apparently the rocker cover has to be replaced, but the good thing is it is something that doesn't have to be done asap as you do not lose tonnes of oil only a very little bit. Personally im going to wait till it gets worse and have my mechanic monitor it on every service.
Cheers
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4605442
Cheers
Yeah someone posted something about this before, "oily spark plugs" can't remember where i read it.
https://www.sau.com.au/forums/topic/239992-rear-axle-click/#findComment-4606620
  • 4 weeks later...
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
    • Placing bets on my stock oem RB25 rods, orrrrrrr........?  馃槀馃拃 for anyone interested, Insta is : @genuine_rb13 https://www.instagram.com/genuine_rb13?igsh=MTR5dGh4NWh0NHg3cA==
    • Hahahahah, look, your not wrong 馃槀馃槀 and thank you brother 馃檹馃徏 jokes aside, I haven't driven the car in 6+ years and it's like I'm starting all over again, and furthermore the car is wayyyy more powerful and it's characteristics are night and day different now compared to what I remember. So I'm slowly easing myself back into the groove, the car is literally scaring me a bit tbh.....it feels like it has 200hp more than it does on paper and responds like a cammed Ls v8, and-some! 馃槄 every single bit of throttle pedal travel and input has instant response all the way to the floor, zero flat spots or labouring feelings, it's nuts. Im shooketh, go easy on me hahahaha or don't 馃馃徏馃槉
    • If the house has ever been sold before too, they have photos from that etc.
    • I used to do that, but then I got savvy. The benefits of having your phone photos geotagged outweigh the negatives. I just don't publish any photo straight off the phone/out of the gallery/off google photos, etc. If I'm going to use a photo, other than for SMSing to fam, I will always open it on the computer, copy it/otherwise edit it and save down without the original metadata, before using it. For example, posting photos of my engine bay into a thread on here, to show someone a plug or something - I will just screen-cap the section I want to use and paste that section direct from the clipboard into the post. No metadata goes along with.
