  • Replies 56
Originally posted by Ryan D
i must be the only skyline driver that listens to heavy music :D
Hell no, I listen to bugger all else (unless my GF is choosing the tracks :D )
Rob Zombie and White Zombie (and the remix albums) are probably the no. 1 chart hits in my car.
cheers,
floody
These are the Initial D Soundtracks I picked up on my trip to Japan.
Initial D - Battle Stage OST
Initial D - Best Selection
Initial D - First Stage OST
Initial D - Second Stage OST
Initial D - Third Stage OST
Initial D - Selection Vol 1
Initial D - Selection Vol 2
Initial D - Selection Vol 3
Initial D - Super Euro Beat
Initial D Second Stage - SPECIAL NON-STOP
Initial D Second Stage - Vocal Battle
Makes for some good cruising tunes :D
"Speedy speed boy ! " lol
cheers,
floody
Can't disaggree there mate. I only listen to Punk/Rock mainly.
Scott
Originally posted by a5h
Evanescence - Going Under
Evanescence - My Imortal
and
Evanescence - Bring me to life
yay! top40 rock kiddies!! :) :)
I should add to what I said above,the Monster Magnet album "God Says No" gets a lot of play in my car.
cheers,
floody
  • 7 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
