Has anyone pushed the limits of a rb20de+t?
There are plenty of people here in NZ pushing well over 300rwkw on rb25de+t setup's with stock internals (completely unopened).
Not much experience i can find here of rb20de+t setup's though.
or if anyone has any comparative photos of rb20de rods vs rb20det rods, or bearing specs etc
i know the higher compression will mean closer attention to tuning is required, but there are many 10:1 compression turbo setup's running high numbers reliably
Thanks
https://www.sau.com.au/forums/topic/240109-limits-rb20det/
You could make 500hp but it might last 12 minutes, what you want is a reliable balance were its going to last a reasonable amount of time before letting go. AD4M over here in WA made 400~HP on one unopened and was fine for ages before letting go.
So maybe 250rwkw is fairly safe with supporting mods and tune.
https://www.sau.com.au/forums/topic/240109-limits-rb20det/#findComment-4193979
  • 7 months later...
Im running an rb20 standard bottom end standard intake manifold with a gt35r .63 standard cams no cam gears was with a chinesse manifold wolf 3d etc etc running 1.5bar made just on 300rwkw 402 rwhp with water meth for about 6mths an no problems yet.touch wood..no just put on 6 boost manifold..all in the tune
https://www.sau.com.au/forums/topic/240109-limits-rb20det/#findComment-4597058
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
