Hi All,
Thought it would be a good idea if we were all to post up what our favourite mods to our cars are. Thinking this will influence eachother to what people have done and what theyve found to be most rewarding mod.
When posting your favourite mod please include how much it cost you, why its your fav. and if its not an "off the shelf" item, where you got it done/made
To kick things off: :(
Favourite Mod:
EBC (electronic boost controller), Greddy Profec B spec II ( $350ish new from whorebay). Followed closely by SAFC II.
Why I Like It:
Made the stagea so much more lively with only a few extra PSI. The ability to have granny spec (Lo) and goodbye petrol mode (hi), I personally think are a must if your driving ur stag as ur only car.
lets see how this goes :)
https://www.sau.com.au/forums/topic/240203-whats-your-favourite-mod/
External gate and TD06 i had on my 180.
Whole setup cost me over 3K
but damn it was worth it seeing the face on the trev went u went past them with the gate screaming and the tyres turning!!
God i miss that car.
But other best mod done for sure was a slightly illegal one :P 25mm wheel spacers, transformed the handling on my R34 drift car, made it sooo stable.
best stagea mod... well havnt driven one long enuf to mod one yet... they keep breaking on me...
Tough call...
In order;
1) Fuji/Kakimoto exhaust combo - niiice sound & very nice increase in power (looks good too :P )
2) Nismo LMX5 rims - work beautifully with the sky blue, huge grip increase over stockies (Kenda types)
3) Opening up airbox - doesn't run out of breath now.... at all.... ever
4) Hi Flow Turbo (T3 core) - only logs in at number 4 because I have not installed the Emanage Ultimate (next - can't wait!) or a boost controller.
too hard to say best mod, for me, lol 'cause Ive done too many
a) hiflow turbocharger (but to choose that you must include the Toshi ecu remap, the safc/sitc/z32afm/adj.fpr/ebc combo) and dynotune setup
b) automatic gearbox shift kit
c) whiteline swaybars and bilstein shocks
More boost... Only mod ive really done as exhuast, induction ect was already on the car...
Why.. Becase its goes harder and i love the look on peoples faces when they hear a wagon screaming past with a nice flutter at the end :dry:
I don't have a favorite and some are not installed in the car year but anyways.
in no particular order
1. Rims (18" BBS Rims - came with the car)
2. Exhaust
3. HKS GT2535 (Not installed - will be very soon)
4. Cooling Pro Stealth Intercooler (Not installed - will be very soon)
5. Blitz SBC iD Spec-R Boost Controller (hopefully to be installed this weekend)
6. Stereo
JJ bellmouth dump with X force hi flo cat and 3" cat back. $400.
My $20 two stage boost control, better than earthing solenoid, caus its controlable and a fuel saver,
well where do i start:
1. $15000 stereo (includes 6 tvs) always entertained
2. Greddy cams love that lumpy idle (louder than my old mans V8)
3. Having a 260rs
4. 300km/h dolphin speedo that was customised to illluminate blue
1. zaust.... nuff said.. that alone is the best bang for buck and gives the car more pickup.
Fuji and hks re pretty pimp..
i was lucky enough for my skyrine to get a CMS custom exhaust ( turbo back) for like 500 bucks.. ( second hand)
And my stag came with one, that with a pod i put on its pretty niiice.
With a fmic id be pretty stoked..
Theres an S15 im looking at now (99% in the bag, deposit down) that has every mod under the sun done to it already bar a turbo ( hes giving me the manifold for it as well).
When i took it for a test drive it made me happy in the pants...looking foward to tomorrow when i pick it up :banana:
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
