Dw, I can hardly get into the back of a Skyline with the seats all the way back. I had to sit in the middle of Niszilla's R34, with my legs behind the passenger cos when he put the seat forward a bit, AND had my head on an angle. I hate being tall sometimes.
Put an R34 GT-R front end and rear on the S14, then throw an RB in there, and you'll have something unique! (Yes, that has been done without the RB engine)
i call bs
LOL, I originally did look at some Soarers (from car-sales) around the same time I was asking you for skyline infos, but the TT version I looked at turned out to be $1.5k more (compared to my R33) & 1 turbo not in great condition... while the other ones I looked at were all V6/V8 ones.
My parents liked them though, due to the Lexus badge on some of them...
Yeah most the time it's ok but, I was giving a lift to 2 friends the other day and 1 of them was trying to fit in the back. It was so bad he decided to get out and drive his commodore instead. :)
thats exactly what i want.. i hate playing taxi :P
They made v6 soarers?:dry:
^^^ There was a couple of 3L 6cyl NA Soarers I saw, could be straight 6s instead of V6s, not quite sure...
30 Series Soarer models
* JZZ30 - 2.5L 6 cyl twin turbo (1991-1996)
* JZZ30 - 2.5L 6 cyl single turbo VVTi (1996-2000)
* JZZ31 - 3.0L 6 cyl (US Lexus SC 300) (1992-2000)
* UZZ30 - 4.0L 8 cyl (US Lexus SC 400) (1992-2000)
* UZZ31 - 4.0L 8 cyl air suspension (1991-1997)
* UZZ32 - 4.0L 8 cyl 4ws, active suspension (1991-1996)
from: http://en.wikipedia.org/wiki/Toyota_Soarer...s_Soarer_models
Toyota is quite logical with their chassis designations.. if it begine with JZ it means it has a JZ family engine.. 1JZ for 2.5L 2JZ for 3L. UZ for 1UZ v8..
I didn't think there was v6 soarers..
"I did the right thing and got a R32 GTR for my first, I've never looked back since"
MONEY MONEY MONEY
u will soon realise man......and u will also realise that the power u have is never enough......MORE MONEY MONEY MONEY
back on topic...
keep the s14 they are sweet cars with heaps of potential
any pics?...
Edited by nism0man
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
